  <channel>
    <title>MaplePrimes - answers and comments on Question, Can I trade time for memory in Maple?</title>
    <link>http://www.mapleprimes.com/questions/143383-Can-I-Trade-Time-For-Memory-In-Maple</link>
    <language>en-us</language>
    <lastBuildDate>Wed, 10 Jun 2026 20:58:28 GMT</lastBuildDate>
    <pubDate>Wed, 10 Jun 2026 20:58:28 GMT</pubDate>
    <itunes:subtitle />
    <itunes:summary />
    <description>The latest answers and comments added to the Question, Can I trade time for memory in Maple?</description>
    <image>
    </image>
    <item>
      <title>polynomials systems eat memory</title>
      <link>http://www.mapleprimes.com/questions/143383-Can-I-Trade-Time-For-Memory-In-Maple?ref=Feed:MaplePrimes:Can I trade time for memory in Maple?:Comments#answer143515</link>
      <itunes:summary>&lt;p&gt;Unfortunately solving polynomial systems tends to produce exactly this kind of blowup, and there is often little anyone can do. &amp;nbsp;The algorithms generally have to conserve as much memory as possible in order to produce any solution at all&lt;/p&gt;
&lt;p&gt;If you post the system we can try to solve it, but it could also be the case that your problem is too hard at present.&lt;/p&gt;
&lt;p&gt;This is an area of active research so I encourage you to post the system.&lt;/p&gt;</itunes:summary>
      <description>&lt;p&gt;Unfortunately solving polynomial systems tends to produce exactly this kind of blowup, and there is often little anyone can do. &amp;nbsp;The algorithms generally have to conserve as much memory as possible in order to produce any solution at all&lt;/p&gt;
&lt;p&gt;This is an area of active research so I encourage you to post the system.&lt;/p&gt;</description>
      <guid>143515</guid>
      <pubDate>Fri, 15 Feb 2013 11:48:01 Z</pubDate>
      <itunes:author>roman_pearce</itunes:author>
      <author>roman_pearce</author>
    </item>
    <item>
      <title>Actually it is a semi-algebraic system ...</title>
      <link>http://www.mapleprimes.com/questions/143383-Can-I-Trade-Time-For-Memory-In-Maple?ref=Feed:MaplePrimes:Can I trade time for memory in Maple?:Comments#comment143726</link>
      <itunes:summary>&lt;p&gt;Roman thanks a lot for your answer. First let me apologize: the Groebner package does work fine (unlike I posted previously) in the Linux cluster -- but not on my laptop :-)&lt;br&gt;&lt;br&gt;The problem was with the package RegularChains that I have to use since my ultimate goal is to prove the existence of an unique real solution in the interior of (0,1)^16 (in the 16 x 16 example/case) - we economists always have to deal with constraints so localization and isolation are very important to us.&lt;br&gt;&lt;br&gt;My first attempt was to generate a lex Groeber basis for the system (it takes few secs in the Linux cluster) and then fed the solution to RealRootCounting of RegularChains/SemiAlgebraicSetTools package but RealRootCounting's algorithm is very slow for my problem. After 5 days running I killed the process.&amp;nbsp; Skipping second attempt story... In my final attempt, I fed the lex Grobner basis but with its first equation simplified (the solution of the 12 x 12 case tells me what roots of the 16 x 16 case are not in (0,1)^16 -- due to the specifics of the problem) to IsolateRealRoots also in the RegularChains package. It took a total of 29 secs and I got the output, which is just one box. If I understood correctly the description of the command,&lt;br&gt;&lt;br&gt;"The RealRootIsolate command returns a list of boxes. Each box isolates exactly one real root of the regular chain rc or semi-algebraic system S whose polynomial equations, non-negative polynomial inequalities, (strictly) positive polynomial inequalities and polynomial inequations are given respectively by F, N, P, and H. Moreover, it is guaranteed that all real solutions are found."&lt;br&gt;&lt;br&gt;having just one box means the solution exists and is unique. In the end of the story I was puzzled with the performance of RealRootCounting, with RealRootIsolate I used method='Discoverer'. RealRootCounting does not support a method option.&lt;br&gt;&lt;br&gt;Thanks again!&lt;/p&gt;</itunes:summary>
      <description>&lt;p&gt;Roman thanks a lot for your answer. First let me apologize: the Groebner package does work fine (unlike I posted previously) in the Linux cluster -- but not on my laptop :-)&lt;br&gt;&lt;br&gt;The problem was with the package RegularChains that I have to use since my ultimate goal is to prove the existence of an unique real solution in the interior of (0,1)^16 (in the 16 x 16 example/case) - we economists always have to deal with constraints so localization and isolation are very important to us.&lt;br&gt;&lt;br&gt;My first attempt was to generate a lex Groeber basis for the system (it takes few secs in the Linux cluster) and then fed the solution to RealRootCounting of RegularChains/SemiAlgebraicSetTools package but RealRootCounting's algorithm is very slow for my problem. After 5 days running I killed the process.&amp;nbsp; Skipping second attempt story... In my final attempt, I fed the lex Grobner basis but with its first equation simplified (the solution of the 12 x 12 case tells me what roots of the 16 x 16 case are not in (0,1)^16 -- due to the specifics of the problem) to IsolateRealRoots also in the RegularChains package. It took a total of 29 secs and I got the output, which is just one box. If I understood correctly the description of the command,&lt;br&gt;&lt;br&gt;"The RealRootIsolate command returns a list of boxes. Each box isolates exactly one real root of the regular chain rc or semi-algebraic system S whose polynomial equations, non-negative polynomial inequalities, (strictly) positive polynomial inequalities and polynomial inequations are given respectively by F, N, P, and H. Moreover, it is guaranteed that all real solutions are found."&lt;br&gt;&lt;br&gt;having just one box means the solution exists and is unique. In the end of the story I was puzzled with the performance of RealRootCounting, with RealRootIsolate I used method='Discoverer'. RealRootCounting does not support a method option.&lt;br&gt;&lt;br&gt;Thanks again!&lt;/p&gt;</description>
      <guid>143726</guid>
      <pubDate>Thu, 21 Feb 2013 10:34:30 Z</pubDate>
      <itunes:author>Sergio Parreiras</itunes:author>
      <author>Sergio Parreiras</author>
    </item>
    <item>
      <title>my system</title>
      <link>http://www.mapleprimes.com/questions/143383-Can-I-Trade-Time-For-Memory-In-Maple?ref=Feed:MaplePrimes:Can I trade time for memory in Maple?:Comments#comment144719</link>
      <itunes:summary>&lt;p&gt;Sometimes Maple solves a smaller version i:=4 very fast (2000 or 5000 seconds) but sometimes even the smaller version runs forever and ever - even if I askf or the same amount of resources: memory, CPU time, swap memory, processors! I am starting to suspect that are some gremlins at work...&lt;/p&gt;
&lt;p&gt;&lt;a href="/view.aspx?sf=144719/456288/G3.txt"&gt;G3.txt&lt;/a&gt;&lt;/p&gt;</itunes:summary>
      <description>&lt;p&gt;Sometimes Maple solves a smaller version i:=4 very fast (2000 or 5000 seconds) but sometimes even the smaller version runs forever and ever - even if I askf or the same amount of resources: memory, CPU time, swap memory, processors! I am starting to suspect that are some gremlins at work...&lt;/p&gt;
&lt;p&gt;&lt;a href="/view.aspx?sf=144719/456288/G3.txt"&gt;G3.txt&lt;/a&gt;&lt;/p&gt;</description>
      <guid>144719</guid>
      <pubDate>Sun, 17 Mar 2013 08:20:46 Z</pubDate>
    </item>
  </channel>
</rss>
