Question: How to insert new paragraph on its own "group" and not inside an existing "group"
March 09 2014 nm 1170
Using worksheet mode. It is a strugle to add a new paragraph on its own group so I can document some code.
I open new worksheet, and type a Maple command. say
x:=10; and hit return.
Now the screen looks like
|>x:=10;
|                        x:=10
|>     curser is here now    (1)
Now I want to make new paragraph, on its own group, before I type new command. (I need it on its own group, to fix another Maple latex export issue) i..e I want it to look like
|>x:=10;
|                        x:=10
|   this is pargraph I wanted to create
|>     curser is here now    (2)
However, this is not possible using one command.  when in (1) above, if I tell Maple to insert paragraph->Before cursor, it does this:
|>x:=10;
|                        x:=10
|  it created a paragraph- here, but this is still in the same group as (1) below
Only way I found to do it is this: create an execution group before the cursor. Then go back to that execution group. Then do insert paragraph->Before cursor, then delete the execution group just created, leaving the paragraph on its own group:
Step 1
|>x:=10;
|                        x:=10
|> create this as execution group
Step 2
|>x:=10;
|                        x:=10
|   create paragraph here
step 3, delete the execution group, leaving the paragraph
|>x:=10;
|                        x:=10
|   leaving paragraph on its own here
there got to be a simpler way? I am using Maple 18 on windows 7. (64 bit)
