Question: How to use a table in the standard GUI
May 09 2014 Mac Dude 862
Maple
In order to make worksheets more interactive in a teaching environment I have begun playing around with the Tables the standard GUI provides. The idea is that in the left column is the script we are working through while in the right column is space a student can work with the equations and formulae from the left side to, e.g., plot, change parameters etc. without affecting the script too much.
To build the tables I copy-pasted code from a normal worksheet (in document mode) into the left column, creating rows of appropriate length to have a logically coherent section in one row. Usually one row is one Section (in the technical sense of Maple Sections). The student gets to play in the right column.
In principle this seems to work quite well in my preliminary testing. I did find out rather quickly that on the right side one needs to be in 1-d input mode with a prompt for anything to be calculated interactively. Ok, actually probably easier to do. The table is set to evaluate by row so the right-left correspondence is preserved.
A potential issue I am facing however is with equation numbering: I use equation numbers extensively to reference back to upstream results. In the Table, it appears that equation numbers are not unique; in each row of the Table, eq. numbers start as (1.1), (1.2) etc. I am able to reference back to results from a prior row, even though the same equation number will show up again later in the new row. But I am concerned that eventually this all ends up in a big mess and my references point to the wrong expression or equation. Non-unique line numbers seem like a Really Bad Idea, and I'd like to avoid that if possible.
Does anyone know how the lines numbers work for code in Tables and how I make sure they are unique? I suppose I could explicitly assign results I need in other rows to names, but that does not prevent a reference to an eq. number from pulling in the wrong one from a prior row (assuming for the moment that Maple will never look forward to resolve a reference).
Thanks,
Mac Dude
