Question: mem usage maple.exe in task manager when high causes issue
May 14 2014 Christopher2222 4274
Maple 18
I was running some wav files through the spectrogram increasing the fft window size.  Generally just playing around.
I have run into an issue.  After running a few times the mem usage for maple.exe starts to run high.  I get it up to 600,000 K and still seems to run okay - ie able to produce a spectrogram.  However running it again at a higher window size of course eats up more memory and right around 1,000,000 K mem usage everything slows down and it appears to freeze.  The spectrogram is not displayed, after a short while CPU usage drops to zero the heartbeat circle (evaluating symbol - bottom left corner) stays solid and everything appears to stop.
It is possible to close the worksheet in the same maple session after some time and open a new one.
Another note.  After one worksheet has ramped up the mem usage to a large value say 800,000 K (it doesn't really matter) .. when I close the worksheet (in the same maple session) the mem usage remains high even after a restart;gc():   I not sure if this has been normal throughout the ages, but I thought after closing a high mem usage worksheet in the same maple session the mem usage in the windows task manager would have updated back down under 100,000 K at least.
The system Maple is running on right now is a P4 3Ghz Windows XP at 2.50 GB RAM Maple 18.00 stnd GUI 32 bit.  Using the spectrograms example in the application center for start.
Any insight as to why the computer starts to freeze up around 1,000,000 K mem usage would be helpful.  Also why closing a worksheet had no effect on the mem usage.  Would be interesting to know if this occurs on other machines as well.
