Question: Physics trouble, again, or what?
June 13 2014 John Fredsted 1386
Consider the following code:
with(LinearAlgebra):
with(Physics):
Setup(anticommutativeprefix = psi):
psiFermi := Vector(2,symbol = psi):
psiBose  := Vector(2,symbol = phi):
A := Matrix([[0,1],[1,0]]):
Transpose(psiFermi) . A;
Transpose(psiBose ) . A;
It produces the following output:
Why is the first line, for anticommuting components, not evaluated to the same form as the second line, for commuting components? The actual choice of the matrix A seems immaterial; the odd behaviour is present even if A is chosen to be the identity matrix!
In comparison, the 'contracted' (scalarly) expressions
Transpose(psiFermi) . A . psiFermi,
Transpose(psiBose ) . A . psiBose;
produce the following completely sensible output:
