Question: Interpolation Using Maple,Procedure, & If Statement
June 26 2014 moses 104
Maple
Good Morning Joe Riel,
Would you be kind to help me with attached work sheet,
1. In the first worksheet the Dynamic-Table, my goal is to read in an excel Table into maple and then do interpolate the given SR-ratio, and lamda-ratio in the maple worksheet attached, I have attached the excel files tables, but have difficulties in reading the data into Maple, and which function to use for the interpolation.
2. My second worksheet “Floating pile” is with regards to if-statement not working and also the procedure d to calculate the spacing between piles from a reference point and also calculating the angles from a reference point,which are also not working.
Regards,
Moses
