Question: Convergence problem in my algorithm DSOLVE
July 08 2014 samiyare 180
I have the a code with some parameters including
Nr= 0, 50, 100
Ha=0, 5, 10
EPSILONE= 0, 0.5, 1
Phiavg= 0.02, 0.06, 0.1
0.1<NBT<10
I can give the solution for higher values of 5<NBT<10 and there is no problem. However, As I reduce the values of NBT, the convergence of the problem is hard. for some values of parameters I cannot find the solution. for example:
Nr=Ha=0
EPSILONE=1
Phiavg=0.06
NBT=0.3
I would be most grateful if you can tel me how change the algorithm to find the solution in the range of all parameters.
Many thanks for your attentions in advance
The code has been attached
code_7-8-2014_(1).mw
Amir
