Question: why calling solve crashes Maple in 2025.2?
Do not know if this is new or not.
I have found about 12 Maple crashes so far in just 2 days running a test in Maple 2025.2
But this one I am not sure if it is new or not as never seen it before.
Could someone please just run this in Maple 2025.1 and see if you get same crash? So I know if it is new or not. Only have Maple 2025.2 on this new PC.
Calling solve causes Maple server to crash. Save your work before just in case.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, 16:4 hours Pacific Time.`
SupportTools:-Version();
sol:=ln( (y-1)^(1/3)* (y^2+y+1)^(1/3) ) - ln(y) = 2/5* ln(t^2+1)+_C1;
ln((y-1)^(1/3)*(y^2+y+1)^(1/3))-ln(y) = (2/5)*ln(t^2+1)+_C1
infolevel[solve]:=5;
5
solve( sol,y);
Main: Entering solver with 1 equation in 1 variable
Dispatch: dispatching to Radicals handler
Transformer:   solving for linear equation in y
Recurse: recursively solving 1 equations and 4 inequations in 1 variables
Dispatch: dispatching to ln handler (extension)
Dispatch: logarithm substitution _S000002 = ln(_S000001)
Dispatch: logarithm substitution _S000003 = ln(t^2+1)
Transformer:   solving for linear equation in _S000003
Recurse: recursively solving 1 equations and 3 inequations in 1 variables
Dispatch: logarithm substitution _S000004 = ln(exp(_S000002)^3+1)
Recurse: recursively solving 2 equations and 3 inequations in 2 variables
Dispatch: logarithm substitution _S000005 = ln(exp(_S000002)^6+3*exp(_S000002)^3+3)
Recurse: recursively solving 3 equations and 3 inequations in 3 variables
Dispatch: dispatching to Exponentials handler
Transformer:   solving for linear equation in _S000005
Recurse: recursively solving 3 equations and 4 inequations in 4 variables
Transformer:   solving for linear equation in _S000004
Recurse: recursively solving 3 equations and 5 inequations in 5 variables
Transformer:   solving for linear equation in _S000002
Recurse: recursively solving 3 equations and 6 inequations in 6 variables
Dispatch: dispatching to Rename handler
Dispatch: renaming exp(5/2*_C1) = _S000012, exp(-5/2*_C1) = 1/_S000012
Dispatch: handling polynomials of the form a*x^n-b
Dispatch: dispatching to PolynomialSystem handler
Main: polynomial system split into 1 parts under preprocessing
Main: using RegularChains based methods
SolverVariableOrder: using the variable order  _S000008 > _S000006 > _S000010
TriangularDecomposition: using deterministic algorithm for decomposition
Download calling_solve_crashes_maple_2025_2_nov_28_2025.mw
Note that this crash happens even when removing Physics update and SupportTools from libname.
