Question: Help regarding solution
Can anyone help me to find the correct solution up to 5 decimal points and how to implement the newton method on the same expression rather than applying fsolve command.pls find mt attachment.
A := -5.032477447*10^(-28)*(-(1/4)*(25*(530.0*lambda+177.7750000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6+(15*(443.3333333*lambda+156.1916667))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(12789.75000+62100.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)+(-12572.66875-60942.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(10265.27500+25610.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-41326.63125-233677.5000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+7.137546188*10^26*(530.0*lambda-858.7250000)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6-1.713011085*10^27*(443.3333333*lambda-725.3083333)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+1.142007390*10^26*(-41261.20625-13307.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+1.142007390*10^26*(36986.22500-16610.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+1.142007390*10^26*(-110668.7437-111922.5000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+1.142007390*10^26*(37205.25000+20700.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)+(-(1/4)*(25*(-20*lambda+29.45))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8+(25*(-20*lambda+29.45))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7+(1/4)*(15*(876.6666667*lambda-1551.891667))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6-(5*(1310.0*lambda-2537.975000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(-52156.91875-11742.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(56847.77500-24190.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-166742.1312-59477.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+(67964.75000-57500.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)-167158.4438-52.50000*lambda)*exp(20.00000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+100.0000000)+((1/4)*(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8-(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7-(1/4)*(15*(876.6666667*lambda+434.6083333))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6+(5*(1310.0*lambda+883.5250000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(-25071.70625-58007.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(33060.72500+15190.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-105784.9938-170922.5000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+(48240.25000-25300.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)-122566.1813-83197.50000*lambda)*exp(20.00000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+40.00000000)+(-(1/4)*(25*(-20*lambda+29.45))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8+(25*(-20*lambda+29.45))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7-(1/4)*(15*(-856.6666667*lambda+2435.941667))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6+(5*(-1290.0*lambda+3683.025000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(-88661.23125+54982.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(67794.77500-15790.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-257173.4437+170197.5000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+(68632.50000+19800.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)-230977.6313+102622.5000*lambda)*exp(5.000000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+1.141301418*10^17*lambda^9-9.737052860*10^16*lambda^8+3.682582968*10^16*lambda^7-8.102838405*10^15*lambda^6+1.142983789*10^15*lambda^5-1.071802621*10^14*lambda^4+6.680654660*10^12*lambda^3-2.668788927*10^11*lambda^2+6.199499765*10^9*lambda-6.379670430*10^7)+((1/4)*(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8-(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7+(1/4)*(15*(-856.6666667*lambda-1407.558333))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6-(5*(-1290.0*lambda-2135.475000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(-65071.14375+14767.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(44343.72500+24790.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-203674.9312+76402.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+(47557.50000+59400.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)-190158.2437+25627.50000*lambda)*exp(5.000000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+1.141301418*10^17*lambda^9-9.737052860*10^16*lambda^8+3.682582968*10^16*lambda^7-8.102838405*10^15*lambda^6+1.142983789*10^15*lambda^5-1.071802621*10^14*lambda^4+6.680654660*10^12*lambda^3-2.668788927*10^11*lambda^2+6.199499765*10^9*lambda-6.379676430*10^7)-7.137546188*10^26*(-20*lambda+29.45)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8+2.855018475*10^27*(-20*lambda+29.45)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7+(-(1/4)*(25*(-20*lambda+29.45))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8+(25*(-20*lambda+29.45))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7-(1/4)*(25*(-510.0*lambda+1533.975000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6+(15*(-423.3333333*lambda+1348.358333))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(-98411.89375+56567.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(85366.22500-23410.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-301081.9312+207202.5000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+(94907.50000-55000.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)-281127.6187+253177.5000*lambda)*exp(25.00000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+1.141301418*10^17*lambda^9-9.737052860*10^16*lambda^8+3.682582968*10^16*lambda^7-8.102838405*10^15*lambda^6+1.142983789*10^15*lambda^5-1.071802621*10^14*lambda^4+6.680654660*10^12*lambda^3-2.668788927*10^11*lambda^2+6.199499765*10^9*lambda-6.379666430*10^7)+(1/4)*(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8-(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7+((1/4)*(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^8-(25*(-20*lambda-3.55))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^7+(1/4)*(25*(-510.0*lambda-927.5250000))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^6-(15*(-423.3333333*lambda-850.1416667))*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^5+(-76318.23125+17682.50000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^4+(64635.27500+14410.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^3+(-254822.1938+122197.5000*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+(78102.50000-24200.00*lambda)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)-249171.5063+194572.5000*lambda)*exp(25.00000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+1.141301418*10^17*lambda^9-9.737052860*10^16*lambda^8+3.682582968*10^16*lambda^7-8.102838405*10^15*lambda^6+1.142983789*10^15*lambda^5-1.071802621*10^14*lambda^4+6.680654660*10^12*lambda^3-2.668788927*10^11*lambda^2+6.199499765*10^9*lambda-6.379672430*10^7)-2.212610768*10^31*lambda-1.114528480*10^31)*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379681930*10^6)/(((5*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+9.5)*exp(20.00000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+40.00000000)+5*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+10.5)*((-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+2.282602836*10^16*lambda^9-1.947410572*10^16*lambda^8+7.365165936*10^15*lambda^7-1.620567681*10^15*lambda^6+2.285967578*10^14*lambda^5-2.143605242*10^13*lambda^4+1.336130932*10^12*lambda^3-5.337577854*10^10*lambda^2+1.239899953*10^9*lambda-1.275935286*10^7)*((-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+2)*((5*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2*(1/4)+2.853253545*10^16*lambda^9-2.434263216*10^16*lambda^8+9.206457420*10^15*lambda^7-2.025709601*10^15*lambda^6+2.857459472*10^14*lambda^5-2.679506552*10^13*lambda^4+1.670163666*10^12*lambda^3-6.671972318*10^10*lambda^2+1.549874942*10^9*lambda-1.594919157*10^7)*exp(5.000000000*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2+1.141301418*10^17*lambda^9-9.737052860*10^16*lambda^8+3.682582968*10^16*lambda^7-8.102838405*10^15*lambda^6+1.142983789*10^15*lambda^5-1.071802621*10^14*lambda^4+6.680654660*10^12*lambda^3-2.668788927*10^11*lambda^2+6.199499765*10^9*lambda-6.379676430*10^7)+5*(-1.141301418*10^16*lambda^9+9.737052862*10^15*lambda^8-3.682582968*10^15*lambda^7+8.102838405*10^14*lambda^6-1.142983789*10^14*lambda^5+1.071802621*10^13*lambda^4-6.680654662*10^11*lambda^3+2.668788927*10^10*lambda^2-6.199499766*10^8*lambda+6.379680930*10^6)^2*(1/4)+2.853253545*10^16*lambda^9-2.434263216*10^16*lambda^8+9.206457420*10^15*lambda^7-2.025709601*10^15*lambda^6+2.857459472*10^14*lambda^5-2.679506552*10^13*lambda^4+1.670163666*10^12*lambda^3-6.671972318*10^10*lambda^2+1.549874942*10^9*lambda-1.594919057*10^7))
-0.5032477447e-27*(-(25/4)*(530.0*lambda+177.7750000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6+15*(443.3333333*lambda+156.1916667)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(12789.75000+62100.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)+(-12572.66875-60942.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(10265.27500+25610.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-41326.63125-233677.5000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.7137546188e27*(530.0*lambda-858.7250000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6-0.1713011085e28*(443.3333333*lambda-725.3083333)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+0.1142007390e27*(-41261.20625-13307.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+0.1142007390e27*(36986.22500-16610.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+0.1142007390e27*(-110668.7437-111922.5000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.1142007390e27*(37205.25000+20700.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)+(-(25/4)*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8+25*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7+(15/4)*(876.6666667*lambda-1551.891667)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6-5*(1310.0*lambda-2537.975000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(-52156.91875-11742.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(56847.77500-24190.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-166742.1312-59477.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+(67964.75000-57500.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)-167158.4438-52.50000*lambda)*exp(20.00000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+100.0000000)+((25/4)*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8-25*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7-(15/4)*(876.6666667*lambda+434.6083333)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6+5*(1310.0*lambda+883.5250000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(-25071.70625-58007.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(33060.72500+15190.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-105784.9938-170922.5000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+(48240.25000-25300.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)-122566.1813-83197.50000*lambda)*exp(20.00000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+40.00000000)+(-(25/4)*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8+25*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7-(15/4)*(-856.6666667*lambda+2435.941667)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6+5*(-1290.0*lambda+3683.025000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(-88661.23125+54982.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(67794.77500-15790.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-257173.4437+170197.5000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+(68632.50000+19800.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)-230977.6313+102622.5000*lambda)*exp(5.000000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.1141301418e18*lambda^9-0.9737052860e17*lambda^8+0.3682582968e17*lambda^7-0.8102838405e16*lambda^6+0.1142983789e16*lambda^5-0.1071802621e15*lambda^4+0.6680654660e13*lambda^3-0.2668788927e12*lambda^2+6199499765.*lambda-63796704.30)+((25/4)*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8-25*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7+(15/4)*(-856.6666667*lambda-1407.558333)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6-5*(-1290.0*lambda-2135.475000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(-65071.14375+14767.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(44343.72500+24790.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-203674.9312+76402.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+(47557.50000+59400.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)-190158.2437+25627.50000*lambda)*exp(5.000000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.1141301418e18*lambda^9-0.9737052860e17*lambda^8+0.3682582968e17*lambda^7-0.8102838405e16*lambda^6+0.1142983789e16*lambda^5-0.1071802621e15*lambda^4+0.6680654660e13*lambda^3-0.2668788927e12*lambda^2+6199499765.*lambda-63796764.30)-0.7137546188e27*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8+0.2855018475e28*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7+(-(25/4)*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8+25*(-20*lambda+29.45)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7-(25/4)*(-510.0*lambda+1533.975000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6+15*(-423.3333333*lambda+1348.358333)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(-98411.89375+56567.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(85366.22500-23410.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-301081.9312+207202.5000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+(94907.50000-55000.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)-281127.6187+253177.5000*lambda)*exp(25.00000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.1141301418e18*lambda^9-0.9737052860e17*lambda^8+0.3682582968e17*lambda^7-0.8102838405e16*lambda^6+0.1142983789e16*lambda^5-0.1071802621e15*lambda^4+0.6680654660e13*lambda^3-0.2668788927e12*lambda^2+6199499765.*lambda-63796664.30)+(25/4)*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8-25*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7+((25/4)*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^8-25*(-20*lambda-3.55)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^7+(25/4)*(-510.0*lambda-927.5250000)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^6-15*(-423.3333333*lambda-850.1416667)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^5+(-76318.23125+17682.50000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^4+(64635.27500+14410.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^3+(-254822.1938+122197.5000*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+(78102.50000-24200.00*lambda)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)-249171.5063+194572.5000*lambda)*exp(25.00000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.1141301418e18*lambda^9-0.9737052860e17*lambda^8+0.3682582968e17*lambda^7-0.8102838405e16*lambda^6+0.1142983789e16*lambda^5-0.1071802621e15*lambda^4+0.6680654660e13*lambda^3-0.2668788927e12*lambda^2+6199499765.*lambda-63796724.30)-0.2212610768e32*lambda-0.1114528480e32)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379681.930)/(((5*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+9.5)*exp(20.00000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+40.00000000)+5*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+10.5)*((-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.2282602836e17*lambda^9-0.1947410572e17*lambda^8+0.7365165936e16*lambda^7-0.1620567681e16*lambda^6+0.2285967578e15*lambda^5-0.2143605242e14*lambda^4+0.1336130932e13*lambda^3-0.5337577854e11*lambda^2+1239899953.*lambda-12759352.86)*((-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+2)*(((5/4)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.2853253545e17*lambda^9-0.2434263216e17*lambda^8+0.9206457420e16*lambda^7-0.2025709601e16*lambda^6+0.2857459472e15*lambda^5-0.2679506552e14*lambda^4+0.1670163666e13*lambda^3-0.6671972318e11*lambda^2+1549874942.*lambda-15949191.57)*exp(5.000000000*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.1141301418e18*lambda^9-0.9737052860e17*lambda^8+0.3682582968e17*lambda^7-0.8102838405e16*lambda^6+0.1142983789e16*lambda^5-0.1071802621e15*lambda^4+0.6680654660e13*lambda^3-0.2668788927e12*lambda^2+6199499765.*lambda-63796764.30)+(5/4)*(-0.1141301418e17*lambda^9+0.9737052862e16*lambda^8-0.3682582968e16*lambda^7+0.8102838405e15*lambda^6-0.1142983789e15*lambda^5+0.1071802621e14*lambda^4-0.6680654662e12*lambda^3+0.2668788927e11*lambda^2-619949976.6*lambda+6379680.930)^2+0.2853253545e17*lambda^9-0.2434263216e17*lambda^8+0.9206457420e16*lambda^7-0.2025709601e16*lambda^6+0.2857459472e15*lambda^5-0.2679506552e14*lambda^4+0.1670163666e13*lambda^3-0.6671972318e11*lambda^2+1549874942.*lambda-15949190.57))
sols := fsolve(A, lambda = -.1 .. 1, maxsols = 4)
0.7016568203e-1, 0.7350618818e-1, .1121166384, -.1, -0.7138204362e-1, -0.7072932196e-1, -0.7072074821e-1
evalf(eval(A, lambda = -0.707231e-1))
Float(undefined)
Download help_solution.mw
