  <channel>
    <title>MaplePrimes - answers and comments on Question, Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.</title>
    <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric</link>
    <language>en-us</language>
    <lastBuildDate>Sat, 04 Apr 2026 16:34:42 GMT</lastBuildDate>
    <pubDate>Sat, 04 Apr 2026 16:34:42 GMT</pubDate>
    <itunes:subtitle />
    <itunes:summary />
    <description>The latest answers and comments added to the Question, Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.</description>
    <image>
    </image>
    <item>
      <title>More of an observation</title>
      <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric?ref=Feed:MaplePrimes:Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.:Comments#answer275690</link>
      <itunes:summary>&lt;p&gt;In your &amp;quot;toy&amp;quot; example&lt;/p&gt;
&lt;p style="margin-left: 40px;"&gt;&lt;span class="mainBody document" id="ctl00_MainContent_body"&gt;diff(u(x), x, x) = u(x), u(0) = 2, u(1) = 1&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="mainBody document"&gt;why would Maple &lt;strong&gt;need&lt;/strong&gt; to return &lt;/span&gt;&lt;span class="mainBody document" id="ctl00_MainContent_body"&gt;diff(u(x), x, x)&amp;nbsp; explicitly? Since diff(u(x), x, x) = u(x), all it needs to return is u(x) - since these functions are obviously identical.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="mainBody document"&gt;dsolve(..,numeric) will never return values for the &amp;quot;highest order derivatives&amp;quot; in an ODE system, because the ODE system itself will allow these to be computed in terms of lower order derivatives (which dsolve(...,numeric) will return).&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="mainBody document"&gt;There are cases where the highest-order derivatives cannot be (easily) isolated and hence computed from the information which dsolve(..,numeric)&amp;nbsp; returns - this is usually where the &amp;quot;trick&amp;quot; of adding a subsidiary equation such as &lt;/span&gt; &lt;span class="mainBody document" id="ctl00_MainContent_body"&gt;diff(u(x), x, x) = v(x) may be useful.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="mainBody document"&gt;So just how difficult is your &lt;strong&gt;actual&lt;/strong&gt; problem??&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;
</itunes:summary>
      <description>&lt;p&gt;In your &amp;quot;toy&amp;quot; example&lt;/p&gt;
</description>
      <guid>275690</guid>
      <pubDate>Sat, 12 Dec 2020 02:07:11 Z</pubDate>
      <itunes:author>tomleslie</itunes:author>
      <author>tomleslie</author>
    </item>
    <item>
      <title>zeroth order approach - using pdsolve</title>
      <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric?ref=Feed:MaplePrimes:Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.:Comments#answer275692</link>
      <itunes:summary>&lt;p&gt;For fun, I tried out&amp;nbsp;your toy problem. In the end, I agree with Tom - I don&amp;#39;t see the difference and neither does Maple. I used pdsolve, not dsolve.&amp;nbsp;&lt;br&gt;
&lt;form name="worksheet_form"&gt;&lt;input name="md.ref" type="hidden" value="C5232BF0EDB025E87F4452C56B7E2A77"&gt;
&lt;table align="center" width="768"&gt;
	&lt;tbody&gt;
		&lt;tr&gt;
			&lt;td&gt;
			&lt;table style="margin-left:0px;margin-right:0px"&gt;
				&lt;tbody&gt;
					&lt;tr valign="baseline"&gt;
						&lt;td&gt;&lt;span style="color:#78000e;font-size: 100%;font-family: Courier New,monospace;font-weight:bold;font-style:normal;"&gt;&amp;gt;&amp;nbsp;&lt;/span&gt;&lt;/td&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="restart" height="23" src="/view.aspx?sf=275692_Answer/ca34479bae21176797627ad302ee352d.gif" style="vertical-align:-6px" width="54"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;span style="color:#000000;font-size: 100%;font-family: Times New Roman,serif;font-weight:normal;font-style:normal;"&gt;&amp;nbsp; &lt;/span&gt;&lt;/p&gt;
			&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;span style="color:#000000;font-size: 100%;font-family: Times New Roman,serif;font-weight:normal;font-style:normal;"&gt;Write out differential equation and boundary value conditions&lt;/span&gt;&lt;/p&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img align="middle" alt="eq := diff(u(x), x, x) = u(x); bvc := u(0) = 2, u(1) = 1" height="102" src="/view.aspx?sf=275692_Answer/a5319e053bd99220a67481eb6d15feec.gif" style="vertical-align:-72px" width="768"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="sol := pdsolve({bvc, eq})" height="23" src="/view.aspx?sf=275692_Answer/c57f77c37e7c76a61085121e6d2aca1a.gif" style="vertical-align:-6px" width="171"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="center" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="u(x) = (-2*exp(2*x-1)+2*exp(1)+exp(2*x)-1)*exp(-x+1)/(exp(2)-1)" height="50" src="/view.aspx?sf=275692_Answer/7838be734d408324c3bb32097860f833.gif" style="vertical-align:-20px" width="326"&gt;&lt;/p&gt;
						&lt;/td&gt;
						&lt;td align="right" style="color:#000000; font-family:Times, serif; font-weight:bold; font-style:normal;"&gt;(1)&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img align="middle" alt="u__sol := eval(u(x), sol); d2u__sol := simplify(diff(u__sol, x, x))" height="72" src="/view.aspx?sf=275692_Answer/5133f47c9b93ddb4badcd9ae4b38feb4.gif" style="vertical-align:-55px" width="768"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="center" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="(-2*exp(2*x-1)+2*exp(1)+exp(2*x)-1)*exp(-x+1)/(exp(2)-1)" height="50" src="/view.aspx?sf=275692_Answer/252561b6ba9cfa37f320adada4b506b1.gif" style="vertical-align:-20px" width="287"&gt;&lt;/p&gt;
						&lt;/td&gt;
						&lt;td align="right" style="color:#000000; font-family:Times, serif; font-weight:bold; font-style:normal;"&gt;&amp;nbsp;&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="center" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="(-2*exp(2*x-1)+2*exp(1)+exp(2*x)-1)*exp(-x+1)/(exp(2)-1)" height="50" src="/view.aspx?sf=275692_Answer/8682bcdb39ba9cba72d4bc7b432c4853.gif" style="vertical-align:-20px" width="302"&gt;&lt;/p&gt;
						&lt;/td&gt;
						&lt;td align="right" style="color:#000000; font-family:Times, serif; font-weight:bold; font-style:normal;"&gt;(2)&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="is(u__sol = d2u__sol)" height="28" src="/view.aspx?sf=275692_Answer/8b5f43f5ef1e31318fba0653dc7a69c4.gif" style="vertical-align:-11px" width="103"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="center" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="true" height="23" src="/view.aspx?sf=275692_Answer/083ccb2befc63c5dfce6f173dca4134f.gif" style="vertical-align:-6px" width="30"&gt;&lt;/p&gt;
						&lt;/td&gt;
						&lt;td align="right" style="color:#000000; font-family:Times, serif; font-weight:bold; font-style:normal;"&gt;(3)&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="plot(u__sol, x = 0 .. 1, 0 .. 3)" height="28" src="/view.aspx?sf=275692_Answer/0d07a58579fe47d8b3f1f72d527049fe.gif" style="vertical-align:-11px" width="160"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="center" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img align="middle" height="250" src="/view.aspx?sf=275692_Answer/482644559bf595cf158a49cb9f74bd38.gif" style="border:none" width="300"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;p align="left" style="margin:0 0 0 0; padding-top:0px; padding-bottom:0px"&gt;&lt;img alt="``" height="23" src="/view.aspx?sf=275692_Answer/b1d8bdf538c1eaef288da89a0934201e.gif" style="vertical-align:-6px" width="11"&gt;&lt;/p&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;/td&gt;
		&lt;/tr&gt;
	&lt;/tbody&gt;
&lt;/table&gt;
&lt;input name="sequence" type="hidden" value="1"&gt; &lt;input name="cmd" type="hidden" value="none"&gt;&lt;/form&gt;
&lt;p&gt;&lt;br&gt;
&lt;p&gt;&lt;a href="/view.aspx?sf=275692_Answer/pdsolve.mw"&gt;Download pdsolve.mw&lt;/a&gt;&lt;/p&gt;
</itunes:summary>
      <description>&lt;p&gt;For fun, I tried out&amp;nbsp;your toy problem. In the end, I agree with Tom - I don&amp;#39;t see the difference and neither does Maple. I used pdsolve, not dsolve.&amp;nbsp;&lt;br&gt;
	&lt;tbody&gt;
		&lt;tr&gt;
			&lt;td&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
				&lt;tbody&gt;
						&lt;td&gt;
						&lt;/td&gt;
					&lt;/tr&gt;
				&lt;/tbody&gt;
			&lt;/table&gt;
			&lt;/td&gt;
		&lt;/tr&gt;
	&lt;/tbody&gt;
&lt;/table&gt;
&lt;p&gt;&lt;br&gt;
</description>
      <guid>275692</guid>
      <pubDate>Sat, 12 Dec 2020 03:58:53 Z</pubDate>
      <itunes:author>Scot Gould</itunes:author>
      <author>Scot Gould</author>
    </item>
    <item>
      <title>Differentiating the bvp and what happens for ivp's.</title>
      <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric?ref=Feed:MaplePrimes:Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.:Comments#answer275704</link>
      <itunes:summary>&lt;pre class="prettyprint"&gt;
ode1:=diff(u(x), x, x) = u(x)*sin(x);
ode2:=diff(ode1,x);
bcs:=u(0)=2,u(1)=1,(D@@2)(u)(1)=sin(1);
Digits:=10: # The default
res:=dsolve({ode2,bcs},numeric,abserr=1e-13);
plots:-odeplot(res,[x,diff(u(x),x,x)-u(x)*sin(x)],0..1,caption=typeset(diff(u(x),x,x)-u(x)*sin(x)));
&lt;/pre&gt;
&lt;p&gt;&lt;img src="data:image/png;base64,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" /&gt;&lt;/p&gt;
&lt;p&gt;A comment or rather a rhetorical question:&lt;/p&gt;
&lt;p&gt;If you were to design an algorithm for dsolve/numeric (bvp or ivp) that returned the highest derivative too, what would you make it return other than the right hand side?&lt;br /&gt;
#####&lt;br /&gt;
Looking at what `dsolve/numeric` does to an ivp like this:&lt;br /&gt;
ode2:=v(x)=diff(u(x),x,x);
ics:=u(0)=2,D(u)(0)=0;
#debug(`dsolve/numeric`);
res:=dsolve({ode1,ode2,ics},numeric,abserr=1e-13,relerr=1e-10);
plots:-odeplot(res,[x,v(x)-u(x)*sin(x)],0..1,caption=typeset(v(x)-u(x)*sin(x)));
&lt;/pre&gt;
&lt;p&gt;If you remove the # then the debugging output reveals what dsolve/numeric does here:&lt;br /&gt;
&amp;nbsp;&lt;/p&gt;
INFO[&amp;quot;proc&amp;quot;] := proc(N, X, Y, YP) local Z1; Z1 := Y[1]*sin(X); Y[3] := Z1; if N &amp;lt; 1 then return 0; end if; YP[2] := Z1; YP[1] := Y[2]; 0; end proc;&lt;/pre&gt;
&lt;p&gt;As you see the right hand side is kept in the local Z1 and Y[3] (i.e. v) gets that value as does YP[2] i.e. u&amp;#39;&amp;#39;.&lt;br /&gt;
This simply means that the right and side is returned for v.&lt;/p&gt;
</itunes:summary>
      <description>&lt;pre class="prettyprint"&gt;
ode2:=diff(ode1,x);
&lt;/pre&gt;
#####&lt;br /&gt;
&lt;/pre&gt;
</description>
      <guid>275704</guid>
      <pubDate>Sat, 12 Dec 2020 15:14:44 Z</pubDate>
      <itunes:author>Preben Alsholm</itunes:author>
      <author>Preben Alsholm</author>
    </item>
    <item>
      <title>@tomleslie&amp;nbsp;Analytically they&amp;#39;re identic...</title>
      <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric?ref=Feed:MaplePrimes:Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.:Comments#comment275691</link>
      <itunes:summary>&lt;p&gt;&lt;a href="/questions/231217-Second-Derivative-For-Dsolve-Numeric#answer275690"&gt;@tomleslie&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Analytically u&lt;sub&gt;xx&lt;/sub&gt; and u &lt;em&gt;are&lt;/em&gt; identical, but numerically they might not be. That&amp;#39;s part of what I want to find out.&lt;/p&gt;
&lt;p&gt;And in my real problem, the second derivative, u&lt;sub&gt;xx&lt;/sub&gt; = f(u(x),s(x)), where f is a complicated nonlinear function&amp;nbsp;of u(x), and s(x) is a piecewise continuous coeffient&amp;nbsp;(piecewise in the independent variable x). So I am more concerned that that f(u,s) might deviate from&amp;nbsp;u&lt;sub&gt;xx&lt;/sub&gt; than in the toy problem.&lt;/p&gt;
&lt;p&gt;Setting f(u(x),s(x)) = 0 and solving for x gives an analytical&amp;nbsp;prediction where the inflection should be.&amp;nbsp;The numerical result is&amp;nbsp;very close to this analytical prediction, but not quite equal to it. Is the analytical prediction wrong or is the numerical solution inaccurate? The dependent variable, u(x) is almost linear at the inflection point, so near the minimum, du/dx is pretty flat -- small changes in u lead to large changes in x. Hence I need the most accurate calculation of u&lt;sub&gt;xx&lt;/sub&gt; that I can muster. Currently I&amp;#39;m stuck with finite difference approximations applied to dsolve&amp;#39;s estimate of u.&lt;/p&gt;
&lt;p&gt;Eventually, I would like to prove analytically that the f(u(x),s(x)) = 0 prediction of the location of the inflection point is correct. Before putting in the effort to do that, though, I want some numerical confirmation that the prediction is probably correct.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Another problem is that it&amp;#39;s hard to get dsolve to converge for abserr &amp;gt;&amp;nbsp;&amp;asymp; 10^-4, perhaps because of the piecewise coefficient -- so I can&amp;#39;t calculate the solution with unlimited precision.&lt;/p&gt;
</itunes:summary>
      <description>&lt;p&gt;&lt;a href="/questions/231217-Second-Derivative-For-Dsolve-Numeric#answer275690"&gt;@tomleslie&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
</description>
      <guid>275691</guid>
      <pubDate>Sat, 12 Dec 2020 03:13:46 Z</pubDate>
      <itunes:author>Robert Matlock</itunes:author>
      <author>Robert Matlock</author>
    </item>
    <item>
      <title>How would it be done?</title>
      <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric?ref=Feed:MaplePrimes:Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.:Comments#comment275694</link>
      <itunes:summary>&lt;p&gt;&lt;a href="/questions/231217-Second-Derivative-For-Dsolve-Numeric#comment275691"&gt;@Robert Matlock&lt;/a&gt;&amp;nbsp;Suppose that&amp;nbsp;&lt;strong&gt;dsolve&lt;/strong&gt;&amp;nbsp;did provide the highest-order derivative in its output. By what magic process would it compute that other than the way that we&amp;#39;re describing to you?&amp;nbsp;&lt;/p&gt;
</itunes:summary>
      <description>&lt;p&gt;&lt;a href="/questions/231217-Second-Derivative-For-Dsolve-Numeric#comment275691"&gt;@Robert Matlock&lt;/a&gt;&amp;nbsp;Suppose that&amp;nbsp;&lt;strong&gt;dsolve&lt;/strong&gt;&amp;nbsp;did provide the highest-order derivative in its output. By what magic process would it compute that other than the way that we&amp;#39;re describing to you?&amp;nbsp;&lt;/p&gt;
</description>
      <guid>275694</guid>
      <pubDate>Sat, 12 Dec 2020 04:52:29 Z</pubDate>
      <itunes:author>Carl Love</itunes:author>
      <author>Carl Love</author>
    </item>
    <item>
      <title>@Carl Love&amp;nbsp;Clearly you&amp;#39;ve not read what...</title>
      <link>http://www.mapleprimes.com/questions/231217-Second-Derivative-For-Dsolve-Numeric?ref=Feed:MaplePrimes:Second derivative for dsolve numeric solution of second order BOUNDARY VALUE PROBLEM.:Comments#comment275695</link>
      <itunes:summary>&lt;p&gt;&lt;a href="/questions/231217-Second-Derivative-For-Dsolve-Numeric#comment275694"&gt;@Carl Love&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Clearly you&amp;#39;ve not read what I wrote above. Nor have you paid attention to the fact that I posed a simple problem for the purpose of illustration -- the actual problem I need to solve is not solvable analytically.&lt;/p&gt;
&lt;p&gt;I am not sure how error is tallied on quantities calculated by dsolve. If it is independent for each quantity, then a reasonable upper bound for&amp;nbsp;|u&lt;sub&gt;xx&lt;/sub&gt;(x)&amp;nbsp;- u(x)| &amp;nbsp;is |u&lt;sub&gt;xx&lt;/sub&gt;(x)&amp;nbsp;- u(x)| &amp;le; 2*abserr -- i.e. for numerical results u&lt;sub&gt;xx&lt;/sub&gt;&amp;nbsp;&amp;nbsp;&amp;ne; u(x).&lt;/p&gt;
&lt;p&gt;Second, on June 10, 2012,&amp;nbsp;Dave L 472 posted the following regarding higher order derivatives from dsolve numeric:&lt;/p&gt;
&lt;p&gt;&amp;quot;&lt;em&gt;There are have been quite a few questions on Mapleprimes, about numerically deriving additional information from the solutions returned by dsolve(..,numeric). That includes higher derivatives, integrals, inverting for particular function values, etc.&lt;/em&gt;&lt;/p&gt;
&lt;p&gt;&lt;em&gt;As it happens, I was having coffee last week with the principle developer of dsolve,numeric, and I asked him pointedly about all this. The answer I got back was pretty unequivocal: dsolve itself is the best thing to use in these situations, in general, because it will try to ensure that the requested accuracy (whether specified by default or explicit tolerance options) is attained for the requested quantities.&lt;/em&gt;&lt;/p&gt;
&lt;p&gt;&lt;em&gt;Consider fdiff (or evalf@D, which has a hook to fdiff). It will not compute as carefully as dsolve,numeric would. If dsolve,numeric detects difficulties near a requested point then it can automatically adjust stepsizes, etc. But that won&amp;#39;t happen when using fdiff.&amp;quot;&lt;/em&gt;&lt;/p&gt;
&lt;p&gt;&lt;em&gt;Let&amp;#39;s compare the two methods given so far, pushed out only as far as the modest value of t=2.0. Fortunately we can compare against the exact result, which can be evalf&amp;#39;d at high working precision.&lt;/em&gt;&lt;/p&gt;
&lt;p&gt;&lt;em&gt;As we can see below, the result from dsolve,numeric itself is pretty much accurate up to its own default tolerances (which is incorporated into the procedures which it returns). The nested fdiff results, on the other hand, get wildly wrong as Digits changes.&lt;/em&gt;&amp;quot;&lt;/p&gt;
</itunes:summary>
      <description>&lt;p&gt;&lt;a href="/questions/231217-Second-Derivative-For-Dsolve-Numeric#comment275694"&gt;@Carl Love&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
</description>
      <guid>275695</guid>
      <pubDate>Sat, 12 Dec 2020 05:21:52 Z</pubDate>
    </item>
  </channel>
</rss>
