This question is related to the
Question
Event iteration
Hi!
I have the same problem.
"Simulation problem: maximum number of event iterations reached (100) at t= ...."
I have a model which worked without problem in maplesim2, using a lot of event iterations. The model can only work this way, becouse its a mechanic model where the friction is function of the sliding speed, thus where the speed changes value, the friction coefficient does also, and an event occurs.
I really need to know where can i change in maplesim the default vaue of 100 iterations, so the model can run.
Thank you;
