How can I model a ground pattern, like was done in the demos of the planetary rover (http://www.maplesoft.com/products/maplesim/demo/OrangWowMoment.aspx)?
I see in the block model of the planetary rover that there is a component called "ground pattern" and it is not connected to any of the other components of the model, and this component is also not part of any default libraries of Maplesim.
Is there an easy way to model the ground in Maplesim without using a CAD geometry and signal references for the height of the wheels? Is it possible to get the "ground pattern" component used in the planetary rover modeling?
