I'm running a 2D parameter sweep from Maple 15 on a MapleSim 5 model. The output is stored in a 2D matrix. I've encountered two problems:
1) when I graph it with matrixplot the z-axis values are fine but I can't figure out how to change the x-axis and y-axis values from the matrix indices to the actual values of the swept parameters.
2) When the parameter sweep begins I get a warning about storing the values in a matrix. Maple says "Parts of the expression are ambiguous. Please select one of the suggested meanings": (1) Function defintion, or (2) Remember table assignment.
I select table assignment and it works. I'd like to fine a less "ambiguous" way of doing this.
Here's the Maple code that I'm using:
Using the matrixplot command I get a graph like this:
Any guidance on how to do this better is much appreciated!
Thanks,
James
