Question: DEPlot Error When Plotting Solution Curve
February 06 2013 DJJerome1976 355
Maple 16
2
I just encountered a very strange behavior when using DEplot. I want to generate a slopefield and solution curves. However, when I enter the command, only the arrows in the slopefield are showing. If I click on the plot where the solution curve should be, I see the outline of the curve. It's as if the curve isn't begin colored. I hope someone is able to replicate this behavior and suggest a fix. Thanks! (See attached file) DEplot_error.mw
