Question: Maybe a limitation to RunWorksheet?
Hi everybody,
I am used to using  the DocumentTools :-RunWorksheet command and I am confronted with the following problem :
  • My worksheet is deemed to generate a plot in a png file
    > plotsetup(png, plotoutput=MyFile, …)
    > plot( …)
    But MyFile is not created
  • Thinking that the mw file launched by  DocumentTools :-RunWorksheet is seen as a procedure, I have thought that print(plot(…)) would fix the issue.
    Unfortunately the png file is still not created (same behavior with a jpeg file)
I know that  DocumentTools :-RunWorksheet is “experimental” but I wonder if I am doing something wrong or if DocumentTools :-RunWorksheet simply does not support plots?
Thanks in advance
