Question: Drawing a polygonal approximation of a curve C
I try to make a procedure for this
Was it by a example of Riemann sum that  x-values in a array are stored for  numerical value, but in this task it seems that the array must be filled with the symbol x1,x2 , etc
Should this be needed ?
blz64.pdf
blz_65.pdf
excset  3  task4
Was it first for a partition about a interval ( example Riemannn sum) that i got  a list of numeric values
 a:= 0: b:= 5: N:= 30: i= 0..N :
X:= Array(0..N, [seq(j, j=a..b, (b-a)/N)]);
Array(%id = 18446745862042054398)
Now i want  to get a list  of  x-values in Array X ,  starting from  0  to N  :
example: array X =[x0= 0, x1=1/6, ...]
x[i]:= a+(b-a)*i/N; # for i = 0..N # endpoints subintervals
Error, invalid terms in product: 0 .. 30
# generate X-values for interval [a,b]
X:= Array(0..N, [seq(j, j=a..b, x[i])]);
Error, invalid input: seq expects its 3rd argument, step, to be of type numeric, but received x[i]
the values  x1,x2....stored  in Array X are used in further calulations
If there is a need for naming x1= 0 , x2= ..  in the Array A ? , probably not .
Download vraag_excset3_task_4.mw
