Question: Equivalent of currentdir, but not to get current working directory, instead getting directory of the file that is being read.
Is there an equivalent of currentdir() which instead of returning current working directory, returns the directory of the file being read. So assume I have an ".mm" or ".mpl" file saved in some location and there is another file with a location fixed relative to this file, but not fixed in absolute location on the computer and not fixed relative with current working directory. One natural thing is to have a line in the first file that takes its current location (not current working location of the user!) and then use the fixed relative path info, and then gives the location of the second file to the user. Using currendir won't help here because current working directory is not necessarily the same as the location of the file you are reading, the first file. One may say the user is reading the first file so he knows already its location, right? Well, if the user is also the writer of the file, sure, not a problem, he can manually edit the lines of the file and put that location inside the file instead of using currentdir etc. However, if the user is not the writer and also does not know how to edit or whatever else reason, then the file should be able to inform Maple of its own location, so that's why something like currentdir() but not for the working directory, instead for currently being read file's directory is helpful. I checked FileTools package quickly and couldn't notice anything like what I want. Anyone have any clue on name of such command if exists or any other trick that does what I want (except expecting the user to do something ^_^ so all from the writer's side please ^_^).
