Question: Is it possible to output the location of each bifurcation point of the logistic equation?
Good day.
Using the iterative map routine, the location of the bifurcation points of the logistic function can be determined using the plot (see attached).
I was wondering .. is it possible to estimate and output the locations of these points and the range of the function? I would like to explore the bifurcation behavior for the modified function so, this would be a great help.
In this case, the location of the points are: (1.00,0.00), (3.00, 0.66), (3.45, 0.44), (3.45, 0.85) and the range is [0,4].
Thanks for reading!
MaplePrimes_Oct_16.mw
