Question: PDE system in L-shaped cavity
Hello Maple Community,
I'm working on solving a PDE system for fluid flow in an L-shaped cavity (similar to previous work on H-shaped and square domains ) recently asked by some one here. I've implemented the governing equations in Maple but need help generating contour plots.
I'm attaching:
1. My Maple worksheet l_shape_cavity.mw
2. A PDF with the problem description and equations L_shape_cavity_work.pdf
The main issues I'm facing are:
- Setting up proper boundary conditions for the L-shaped domain
- Generating contour plots for velocity and pressure fields
- Ensuring the solution converges properly
Could you please help me with:
1. Correct implementation of the L-shaped domain geometry
2. Generating proper contour plots
3. Any suggestions for improving the numerical solution
Thank you for your assistance!
