Question: expand of a Sum
Hi !
When I use the "expand" command on a summation, I've noticed that sometimes the command works and
sometimes it doesn't. I looked through the previous commands to see which one might be causing this problem.
I found that if I use the "changevar" command  from the "student" package,  (deprecated package,I know )
the "expand" command works correctly.     Strange behavior, isn't it ?       I have Maple 2018 on Windows 10.
Regards  !
There is a small  example in the file.
expand-problem.mw
