Question: How to modify table indices?
I do not use table data struct in Maple and could not find anything in help on how to do this.
given a table T such as the following, typing indices(T) shows there are more than entry in each index
indices(T)
[[-0.687272727272727, -0.687272727272727, 1.],   [2.25818181818182, 2.25818181818182, 1.]],
  [[-2.47, -1.47, 2.], [0.53, 1.53, 2.]],
  [[0.245, -2.755, -2.], [2.745, -0.255, -2.]],
  [[-2.6, -0.6, 3.], [0.379, 2.379, 3.]],
  [[2.659, -1.341, -3.], [4.652, 0.652000000000001, -3.]],
  [[-3.178, 0.822000000000001, 5.], [-1.185, 2.815, 5.]],
  [[0.0672727272727271, -0.932727272727273, 0.], [3.06181818181818, 2.06181818181818, 0.]],
  [[2.8895, -2.1105, -4.], [4.3895, -0.6105, -4.]],
  [[1.01, -0.99, -1.], [4.02571428571429, 2.02571428571429, -1.]],
  [[-3.63, -0.63, 4.], [-1.13875, 1.86125, 4.]]
In the above each entry in table has 2 indices. I want to keep only the first index in each entry so that it has only one, to become this
[[-0.687272727272727, -0.687272727272727, 1.]],
[[-2.47, -1.47, 2.]],
[[0.245, -2.755, -2.]],
 [[-2.6, -0.6, 3.]],
[[2.659, -1.341, -3.]],
 [[-3.178, 0.822000000000001, 5.]],
 [[0.0672727272727271, -0.932727272727273, 0.]],
[[2.8895, -2.1105, -4.]],
[[1.01, -0.99, -1.]],
[[-3.63, -0.63, 4.]]
And keep everything else as in in the Table. Just need to adjust the indices to be one entry instead of 2 or more.
Here is an example of such table
T:=table([([-.687272727272727, -.687272727272727, 1.], [2.25818181818182, 2.258181\
81818182, 1.])=COLOR(RGB,.63529412,.60392157,.60000000),([-2.47, -1.47, 2.], [.\
53, 1.53, 2.])=COLOR(RGB,.60784314,.47450980,.46274510),([.245, -2.755, -2.], [
2.745, -.255, -2.])=COLOR(RGB,.44705882,.52549020,.67058824),([-2.6, -.6, 3.],
[.379, 2.379, 3.])=COLOR(RGB,.57647059,.34509804,.32549020),([2.659, -1.341, -3\
.], [4.652, .652000000000001, -3.])=COLOR(RGB,.34901961,.46666667,.70980392),([
-3.178, .822000000000001, 5.], [-1.185, 2.815, 5.])=COLOR(RGB,.47058824,0.,.\
54901961e-1),([.672727272727271e-1, -.932727272727273, 0.], [3.06181818181818,
2.06181818181818, 0.])=COLOR(RGB,.62352941,.63529412,.65490196),([2.8895, -2.11\
05, -4.], [4.3895, -.6105, -4.])=COLOR(RGB,.22745098,.40392157,.78039216),([1.0\
1, -.99, -1.], [4.02571428571429, 2.02571428571429, -1.])=COLOR(RGB,.53725490,.\
57647059,.65490196),([-3.63, -.63, 4.], [-1.13875, 1.86125, 4.])=COLOR(RGB,.537\
25490,.20392157,.18823529)])
Is it possible to do this in code?
Maple 2025.2
