Question: why Explore gives error when mixing textarea with slider?
Is this a bug?  Or one can not mix slider for one variable and textarea for second variable in Explore?
Or do I need to initialize the textarea is special way? Nothing in help shows an example with textarea and slider together.
No textarea , works OK
Explore(plot(a*sin(b*t),t=0..10),
   parameters=[
        [a=1..20],
        [b=1..20]
  initialvalues=[a=6,b=5],placement='right',width=300);
Change one slider to textarea, now error
   parameters=[
        [a=1..20],
        [b,'controller' = 'textarea','label'="b" ]
Warning, expecting only range variable t in expression 20*sin(b*t) to be plotted but found name b
Warning, expecting only range variable t in expression sin(b*t) to be plotted but found name b
Download explor_feb_19_2026.mw
