Question: Inconsistency between StepProperties and ResponsePlot
I have attached a MapleFlow file that shows a result I don't quite understand.  For some reason the FinalValue result that I get using the DynamicSystems:-StepProperties is different than the steady state value from a DynamicSystems:-ResponsePlot to a unit step using a DifferentialEquation object.
You will notice that I played around a bit, including transforming the DiffEquation object to a TransferFunction object, to see if I could make sense of it.  All of the results are the same as the StepProperties result, it appears that only the ResponsePlot for the DifferentialEquation object is different.
Am I doing something wrong?  Does anyone have any ideas?
Dynamic_Systems_Final_Value.flow
