Question: How to make this code run?
with(plots): with(LinearAlgebra):
# TFSB Coefficients (symbolic in u)
beta0 := u -> (sin(u)*u^3 - 12*u^2 - 24*cos(u) + 24)/(12*(sin(u)*u + 2*cos(u) - 2)*u^2):
beta1 := u -> (5*sin(u)*u^3 + 12*cos(u)*u^2 + 24*cos(u) - 24)/(6*(sin(u)*u + 2*cos(u) - 2)*u^2):
beta2 := u -> beta0(u):
rho0 := u -> ((-u^2-12)*cos(u) - 5*u^2 + 12)/(12*(sin(u)*u + 2*cos(u) - 2)*u^2):
rho1 := u -> (-7*cos(u)*u^3 + 27*sin(u)*u^2 + 120*sin(u) - 120*u)/(60*u^2*(cos(u)*u + 2*u - 3*sin(u))):
rho2 := u -> -rho0(u):
# Secondary coefficients (simplified versions)
beta00 := u -> 13/42 - 9*u^2/7840:
beta10 := u -> 1/6 + u^2/720:
beta20 := u -> 1/42 - 17*u^2/70560:
beta01 := u -> 187/1680 + 611*u^2/705600:
beta11 := u -> 11/30 - 29*u^2/25200:
beta21 := u -> 37/1680 + 67*u^2/235200:
beta02 := u -> 11/70 + 491*u^2/352800:
beta12 := u -> 9/10 - 31*u^2/8400:
beta22 := u -> 31/70 + 811*u^2/352800:
rho01 := u -> 2/105 + 407*u^2/1058400:
rho11 := u -> -19/210 + 41*u^2/105840:
rho21 := u -> -1/168 - 101*u^2/529200:
rho02 := u -> 53/1680 + 1633*u^2/2116800:
rho12 := u -> 8/105 - 4*u^2/6615:
rho22 := u -> -101/1680 - 2273*u^2/2116800:
# Problem definition
omega := 1:
epsilon := 3*Pi/2:
phi := x -> 3*sin(x) - 5*cos(x):  # history function
f := (x, v, vp, vd) -> -v - vd + 3*cos(x) + 5*sin(x):
g := proc(x, v, vp, vd, vdp)
    local fx, fv, fvp, fvd;
    fx := -3*sin(x) + 5*cos(x);
    fv := -1;
    fvp := 0;
    fvd := -1;
    return fx + fv*vp + fvp*0 + fvd*vdp;
# Initial conditions
a := 0: b := 10:
v0 := -5: vp0 := 3:
# Variable step-size parameters
tol := 1e-10:
h_min := 0.01:
h_max := 0.5:
h_init := Pi/8:
# Store results
X := [a]: V := [v0]: Vp := [vp0]:
h_curr := h_init:
x_curr := a:
v_curr := v0:
vp_curr := vp0:
# For history: need v at x-epsilon
get_v_delayed := proc(xx)
    if xx < a then return phi(xx);
    else
        # Interpolate from stored solution
        idx := 1;
        while idx < nops(X) and X[idx] < xx do idx := idx+1; end do;
        if idx = 1 then return phi(xx);
        elif X[idx] = xx then return V[idx];
        else
            # Linear interpolation
            return V[idx-1] + (V[idx]-V[idx-1])*(xx-X[idx-1])/(X[idx]-X[idx-1]);
        end if;
    end if;
# Newton solver for block
solve_block := proc(x0, v0, vp0, h, omega)
    local u, bet0, bet1, bet2, rho0, rho1, rho2, bet00, bet10, bet20, bet01, bet11, bet21, bet02, bet12, bet22,
          rho01, rho11, rho21, rho02, rho12, rho22, F, J, V0, V1, V2, Vp0, Vp1, Vp2, tolN, iter, dv, dV;
    u := omega*h;
    bet0 := beta0(u); bet1 := beta1(u); bet2 := beta2(u);
    rho0 := rho0(u); rho1 := rho1(u); rho2 := rho2(u);
    bet00 := beta00(u); bet10 := beta10(u); bet20 := beta20(u);
    bet01 := beta01(u); bet11 := beta11(u); bet21 := beta21(u);
    bet02 := beta02(u); bet12 := beta12(u); bet22 := beta22(u);
    rho01 := rho01(u); rho11 := rho11(u); rho21 := rho21(u);
    rho02 := rho02(u); rho12 := rho12(u); rho22 := rho22(u);
    # Initial guesses
    V1 := v0 + h*vp0;
    V2 := v0 + 2*h*vp0;
    Vp1 := vp0;
    Vp2 := vp0;
    tolN := 1e-12;
    for iter from 1 to 10 do
        # Compute delayed values
        vd0 := get_v_delayed(x0 - epsilon);
        vd1 := get_v_delayed(x0 + h - epsilon);
        vd2 := get_v_delayed(x0 + 2*h - epsilon);
        vdp0 := (get_v_delayed(x0 - epsilon + 1e-8) - vd0)/1e-8;
        vdp1 := (get_v_delayed(x0 + h - epsilon + 1e-8) - vd1)/1e-8;
        vdp2 := (get_v_delayed(x0 + 2*h - epsilon + 1e-8) - vd2)/1e-8;
        # Compute gamma and g
        gam0 := f(x0, v0, vp0, vd0);
        gam1 := f(x0+h, V1, Vp1, vd1);
        gam2 := f(x0+2*h, V2, Vp2, vd2);
        g0 := g(x0, v0, vp0, vd0, vdp0);
        g1 := g(x0+h, V1, Vp1, vd1, vdp1);
        g2 := g(x0+2*h, V2, Vp2, vd2, vdp2);
        # Residuals
        F1 := h*vp0 - (V1 - v0 + h^2*(bet00*gam0 + bet10*gam1 + bet20*gam2)
              + h^3*(rho01*g0 + rho11*g1 + rho21*g2));
        F2 := h*Vp1 - (V1 - v0 + h^2*(bet01*gam0 + bet11*gam1 + bet21*gam2)
        F3 := h*Vp2 - (V1 - v0 + h^2*(bet02*gam0 + bet12*gam1 + bet22*gam2)
              + h^3*(rho02*g0 + rho12*g1 + rho22*g2));
        F4 := V2 - (2*V1 - v0 + h^2*(bet0*gam0 + bet1*gam1 + bet2*gam2)
              + h^3*(rho0*g0 + rho1*g1 + rho2*g2));
        F := Vector([F1, F2, F3, F4]);
        if LinearAlgebra:-Norm(F) < tolN then break; end if;
        # Approximate Jacobian (finite differences)
        J := Matrix(4,4);
        delta := 1e-6;
        for j from 1 to 4 do
            V_pert := Vector([V1, V2, Vp1, Vp2]);
            V_pert[j] := V_pert[j] + delta;
            V1p := V_pert[1]; V2p := V_pert[2]; Vp1p := V_pert[3]; Vp2p := V_pert[4];
            gam1p := f(x0+h, V1p, Vp1p, get_v_delayed(x0+h-epsilon));
            gam2p := f(x0+2*h, V2p, Vp2p, get_v_delayed(x0+2*h-epsilon));
            g1p := g(x0+h, V1p, Vp1p, get_v_delayed(x0+h-epsilon),
                     (get_v_delayed(x0+h-epsilon+1e-8)-get_v_delayed(x0+h-epsilon))/1e-8);
            g2p := g(x0+2*h, V2p, Vp2p, get_v_delayed(x0+2*h-epsilon),
                     (get_v_delayed(x0+2*h-epsilon+1e-8)-get_v_delayed(x0+2*h-epsilon))/1e-8);
            F1p := h*vp0 - (V1p - v0 + h^2*(bet00*gam0 + bet10*gam1p + bet20*gam2p)
                   + h^3*(rho01*g0 + rho11*g1p + rho21*g2p));
            F2p := h*Vp1p - (V1p - v0 + h^2*(bet01*gam0 + bet11*gam1p + bet21*gam2p)
            F3p := h*Vp2p - (V1p - v0 + h^2*(bet02*gam0 + bet12*gam1p + bet22*gam2p)
                   + h^3*(rho02*g0 + rho12*g1p + rho22*g2p));
            F4p := V2p - (2*V1p - v0 + h^2*(bet0*gam0 + bet1*gam1p + bet2*gam2p)
                   + h^3*(rho0*g0 + rho1*g1p + rho2*g2p));
            Fp := Vector([F1p, F2p, F3p, F4p]);
            J[1..4, j] := (Fp - F)/delta;
        end do;
        dV := LinearAlgebra:-LinearSolve(J, -F);
        V1 := V1 + dV[1]; V2 := V2 + dV[2]; Vp1 := Vp1 + dV[3]; Vp2 := Vp2 + dV[4];
    end do;
    return [V1, V2, Vp1, Vp2];
# Main variable step-size loop
printf("Variable step-size integration for Example 1\n");
printf("tol = %e, h_init = %f\n", tol, h_init);
while x_curr < b - 1e-12 do
    # Try current step
    sol := solve_block(x_curr, v_curr, vp_curr, h_curr, omega);
    V1 := sol[1]; V2 := sol[2]; Vp1 := sol[3]; Vp2 := sol[4];
    # Compute with two half-steps
    sol_half1 := solve_block(x_curr, v_curr, vp_curr, h_curr/2, omega);
    V_mid := sol_half1[2]; Vp_mid := sol_half1[4];
    sol_half2 := solve_block(x_curr + h_curr/2, V_mid, Vp_mid, h_curr/2, omega);
    V2_half := sol_half2[2];
    # Error estimate
    err := abs(V2 - V2_half) / (2^6 - 1);
    if err < tol then
        # Accept step
        x_next := x_curr + 2*h_curr;
        X := [op(X), x_curr + h_curr, x_next];
        V := [op(V), V1, V2];
        Vp := [op(Vp), Vp1, Vp2];
        x_curr := x_next;
        v_curr := V2;
        vp_curr := Vp2;
        printf("x = %7.4f, h = %8.5f, err = %12.5e\n", x_curr, h_curr, err);
        # Adjust step size
        if err < tol/2 then
            h_curr := min(2*h_curr, h_max);
        end if;
    else
        # Reject step, reduce h
        h_curr := max(h_curr/2, h_min);
        printf("  Rejecting, new h = %8.5f\n", h_curr);
    end if;
end do:
# Exact solution for comparison
exact := x -> 3*sin(x) - 5*cos(x);
errors := [seq(abs(V[i] - exact(X[i])), i=1..nops(X))];
# Visualization
p1 := pointplot([seq([X[i], errors[i]], i=1..nops(X))], color=red, symbol=circle,
                title="Example 1: Variable Step-Size TFSB - Absolute Errors",
                labels=["x", "Error"], labeldirections=[horizontal,vertical]);
p2 := plot([[x_curr, h_curr]], x=a..b, style=point, color=blue,
            title="Step-size evolution", labels=["x", "h"]);
display(p1);
display(p2);
printf("\nFinal results for Example 1:\n");
printf("Number of steps: %d\n", nops(X)-1);
printf("Maximum error: %e\n", max(errors));
printf("Final step-size: %f\n", h_curr);
