java runtime error when launching Maple 14
May 06 2010 by alamanya 36
false
Hi, i've got this java runtime error when launching Maple 14 interface. Maple 14 stops after 1 second.
Everything is OK with the classic worksheet interface.
Can you help me please?
Regards,
Alain Le Stang (from France)
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d02e67b, pid=2704, tid=2888
# JRE version: 6.0_17-b04
# Java VM: Java HotSpot(TM) Client VM (14.3-b01 mixed mode windows-x86 )
# Problematic frame:
# C  [awt.dll+0x2e67b]
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x40d56400):  JavaThread "AWT-Windows" daemon [_thread_in_native, id=2888, stack(0x41160000,0x411b0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0xe1e5ac1c
Registers:
EAX=0x0732a4e4, EBX=0xff4e7d99, ECX=0xe1e5ac1c, EDX=0x00000100
ESP=0x411af3bc, EBP=0x00000099, ESI=0x000002dc, EDI=0x00000000
EIP=0x6d02e67b, EFLAGS=0x00010286
Top of Stack: (sp=0x411af3bc)
0x411af3bc:   411af418 00000100 411af49c 00000100
0x411af3cc:   6d0aaa9c 0732a4e4 e1e5ac1c 00000100
0x411af3dc:   00000100 411af618 411af418 00000000
0x411af3ec:   00000000 00000100 40bd7fa0 00000100
0x411af3fc:   00135f60 00000400 e1e5ac1c 00000000
0x411af40c:   00000000 00000100 00000100 00000000
0x411af41c:   00000000 00000100 00000100 00000000
0x411af42c:   00000000 00000004 00000400 00000000
Instructions: (pc=0x6d02e67b)
0x6d02e66b:   ff ff ff c1 e3 08 0b dd 0f b6 28 c1 e3 08 0b dd
0x6d02e67b:   89 19 83 c0 03 83 c1 04 4a 75 da 8b 54 24 20 03
Stack: [0x41160000,0x411b0000],  sp=0x411af3bc,  free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [awt.dll+0x2e67b]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  sun.awt.windows.WToolkit.eventLoop()V+0
j  sun.awt.windows.WToolkit.run()V+69
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x40e7dc00 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=2948, stack(0x415c0000,0x41610000)]
  0x40e26000 JavaThread "WMI:Background Task Runner" [_thread_blocked, id=2944, stack(0x41440000,0x41490000)]
  0x40e03400 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=832, stack(0x413f0000,0x41440000)]
  0x40df8800 JavaThread "Image Fetcher 0" daemon [_thread_in_native, id=960, stack(0x413a0000,0x413f0000)]
  0x40d59c00 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=2896, stack(0x41340000,0x41390000)]
=>0x40d56400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=2888, stack(0x41160000,0x411b0000)]
  0x40d54c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=2884, stack(0x41110000,0x41160000)]
  0x40d33800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2880, stack(0x410c0000,0x41110000)]
  0x40742400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3756, stack(0x40990000,0x409e0000)]
  0x4073bc00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=596, stack(0x40940000,0x40990000)]
  0x4073a400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2544, stack(0x408f0000,0x40940000)]
  0x40739000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2044, stack(0x408a0000,0x408f0000)]
  0x40729000 JavaThread "Finalizer" daemon [_thread_blocked, id=2548, stack(0x40850000,0x408a0000)]
  0x40724400 JavaThread "Reference Handler" daemon [_thread_blocked, id=2672, stack(0x40800000,0x40850000)]
  0x00947c00 JavaThread "main" [_thread_blocked, id=2276, stack(0x009e0000,0x00a30000)]
Other Threads:
  0x40721400 VMThread [stack: 0x407b0000,0x40800000] [id=2676]
  0x4075dc00 WatcherThread [stack: 0x409e0000,0x40a30000] [id=2428]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 960K, used 953K [0x02ae0000, 0x02be0000, 0x071a0000)
  eden space 896K, 100% used [0x02ae0000, 0x02bc0000, 0x02bc0000)
  from space 64K,  90% used [0x02bc0000, 0x02bce760, 0x02bd0000)
  to   space 64K,   0% used [0x02bd0000, 0x02bd0000, 0x02be0000)
 tenured generation   total 4096K, used 2298K [0x071a0000, 0x075a0000, 0x3c2e0000)
   the space 4096K,  56% used [0x071a0000, 0x073de8e8, 0x073dea00, 0x075a0000)
 compacting perm gen  total 12288K, used 9654K [0x3c2e0000, 0x3cee0000, 0x402e0000)
   the space 12288K,  78% used [0x3c2e0000, 0x3cc4d918, 0x3cc4da00, 0x3cee0000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0041f000  C:\Program Files\Maple 14\jre\bin\maple.exe
0x7c910000 - 0x7c9c9000  C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000  C:\WINDOWS\system32\KERNEL32.dll
0x60000000 - 0x6003b000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\midas32.dll
0x61000000 - 0x61027000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\plugin_base.m32
0x67000000 - 0x67043000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\plugin_nt.m32
0x64000000 - 0x64021000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\plugin_registry.m32
0x62000000 - 0x6202d000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\plugin_extra.m32
0x65000000 - 0x6501a000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\plugin_net.m32
0x63000000 - 0x63051000  C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_60\plugin_fragments.m32
0x77da0000 - 0x77e4c000  C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee2000  C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000  C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000  C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000  C:\WINDOWS\system32\GDI32.dll
0x76320000 - 0x7633d000  C:\WINDOWS\system32\IMM32.DLL
0x7c340000 - 0x7c396000  C:\Program Files\Maple 14\jre\bin\msvcr71.dll
0x6d800000 - 0x6da8b000  C:\Program Files\Maple 14\jre\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000  C:\WINDOWS\system32\WINMM.dll
0x6d7b0000 - 0x6d7bc000  C:\Program Files\Maple 14\jre\bin\verify.dll
0x6d330000 - 0x6d34f000  C:\Program Files\Maple 14\jre\bin\java.dll
0x6d290000 - 0x6d298000  C:\Program Files\Maple 14\jre\bin\hpi.dll
0x76ba0000 - 0x76bab000  C:\WINDOWS\system32\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000  C:\Program Files\Maple 14\jre\bin\zip.dll
0x6d000000 - 0x6d14a000  C:\Program Files\Maple 14\jre\bin\awt.dll
0x72f50000 - 0x72f76000  C:\WINDOWS\system32\WINSPOOL.DRV
0x77be0000 - 0x77c38000  C:\WINDOWS\system32\msvcrt.dll
0x774a0000 - 0x775dd000  C:\WINDOWS\system32\ole32.dll
0x77390000 - 0x77493000  C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x77f40000 - 0x77fb6000  C:\WINDOWS\system32\SHLWAPI.dll
0x5b090000 - 0x5b0c8000  C:\WINDOWS\system32\uxtheme.dll
0x74690000 - 0x746dc000  C:\WINDOWS\system32\MSCTF.dll
0x411f0000 - 0x41219000  C:\Program Files\ScanSoft\OmniPageSE2.0\ophookSE2.dll
0x770e0000 - 0x7716b000  C:\WINDOWS\system32\OLEAUT32.dll
0x77bd0000 - 0x77bd8000  C:\WINDOWS\system32\VERSION.dll
0x75140000 - 0x7516e000  C:\WINDOWS\system32\msctfime.ime
0x6d230000 - 0x6d284000  C:\Program Files\Maple 14\jre\bin\fontmanager.dll
0x4fcf0000 - 0x4fe96000  C:\WINDOWS\system32\d3d9.dll
0x6de60000 - 0x6de66000  C:\WINDOWS\system32\d3d8thk.dll
0x7c9d0000 - 0x7d1f5000  C:\WINDOWS\system32\shell32.dll
0x68000000 - 0x68036000  C:\WINDOWS\system32\rsaenh.dll
0x76960000 - 0x76a16000  C:\WINDOWS\system32\USERENV.dll
0x6fee0000 - 0x6ff35000  C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000  C:\Program Files\Maple 14\jre\bin\net.dll
0x719f0000 - 0x71a07000  C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000  C:\WINDOWS\system32\WS2HELP.dll
0x71990000 - 0x719d0000  C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000  C:\WINDOWS\system32\DNSAPI.dll
0x76f60000 - 0x76f68000  C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000  C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000  C:\WINDOWS\system32\rasadhlp.dll
0x6d450000 - 0x6d474000  C:\Program Files\Maple 14\jre\bin\jpeg.dll
VM Arguments:
jvm_args: -Xmx919m -Ddefault.browser="C:\Program Files\Internet Explorer\IEXPLORE.EXE" -nohome -Dmaple.bin.path=C:\Program Files\Maple 14\bin.win
java_command: com.maplesoft.worksheet.application.WmiWorksheet
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH="C:\WINDOWS\system32\QTJava.zip"
PATH=C:\Program Files\Maple 14\bin.win;C:\Program Files\Maple 14\jre\bin;C:\Program Files\Maple 14\jre\bin\classic;C:\watcom-1.3\binnt;C:\watcom-1.3\binw;C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\Pinnacle\Shared Files\InstantCDDVD\;C:\Program Files\Fichiers communs\Microsoft Shared\Windows Live;C:\Program Files\Microsoft Visual Studio\Common\Tools\WinNT;C:\Program Files\Microsoft Visual Studio\Common\MSDev98\Bin;C:\Program Files\Microsoft Visual Studio\Common\Tools;C:\Program Files\Microsoft Visual Studio\VC98\bin
USERNAME=Alain
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 47 Stepping 0, AuthenticAMD
---------------  S Y S T E M  ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 47 stepping 0, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 1048048k(590628k free), swap 2518476k(2073644k free)
vm_info: Java HotSpot(TM) Client VM (14.3-b01) for windows-x86 JRE (1.6.0_17-b04), built on Oct 11 2009 00:52:06 by "java_re" with MS VC++ 7.1
time: Thu May 06 20:24:22 2010
elapsed time: 1 seconds
Loading Comments & Answers
