Question: How to configure maplelmg's lockfile (/var/tmp/lockmaplelmg) name/location
Since Maple 14 requires a new version of the license manager (which isn't downwards compatible for some reason..), I'm currently trying to figure out how to run two versions of maplelmg on the same Linux host, one for Maple versions 13 and below, one for 14 (and above).
Of course, this would have to happen either on different ports or another IP on the same host, which doesn't really bother me, the problem is that I cannot start two maplelmg's on the same host because I haven't found out how to configure the name/location of the lockfile (which defaults to /var/tmp/lockmaplelmg). This is causing the second maplelmg process to abort during startup beause there's already a lockfile in place.
So, is there any way to configure the location of the lockfile in FLEXlm 11.7 / maplelmg?
Urs
