Question: evalb and sets of eqations
Sorozatok_q1:= proc()
    local solved, n, l, k, s_n, eq1, eq2, `a[1]`, d, MO, ret_length:
    solved := false:
    randomize():
    while ( (not solved) or hasfun([MO], RootOf) ) do
      n   := RandomTools:-Generate(integer(range=5..20)):
      l   := RandomTools:-Generate(integer(range=2..n)):
      k   := RandomTools:-Generate(integer(range= 1..(l-1) )):
      s_n := RandomTools:-Generate(integer(range=5..30)):
      eq1 := abs( `a[1]` +(k-1)*d ) = abs( `a[1]`+(l-1)*d );
      eq2 := n * ( `a[1]` + (`a[1]` + (n-1)*d) )/2 = s_n;
      MO  := solve( [eq1,eq2], [`a[1]`,d], Explicit=true ):
      if not ( MO = [] ) then
         solved := true:
       end if:
    end do:
    ret_length := 4 + nops([MO]):
    return [ret_length, n, k, l, s_n, MO];
Out := Sorozatok_q1();
Out := [5, 9, 3, 9, 28, [[`a[1]` = 28/9, d = 0], [`a[1]` = 140/9, d = -28/9]]]
Out[-1];
Solseq1 := op(map(xxx -> convert(xxx,set), Out[-1]));
Solseq1 := {`a[1]` = 28/9, d = 0}, {`a[1]` = 140/9, d = -28/9}
# copy-paste here the value of Solseq1 from the the previous output line:
Solseq2 := {`a[1]` = 28/9, d = 0}, {`a[1]` = 140/9, d = -28/9};
evalb( {Solseq1} = {Solseq2});
false
Solseq1[1];
Solseq2[1];
evalb( Solseq1[1] = Solseq2[1] );
false
# copy-paste here the previous 2 ( identical :) sets:
evalb({`a[1]` = 28/9, d = 0} = {`a[1]` = 28/9, d = 0});
true
Download set-evalb.mw
Why do we get the "false "outputs here?
