Question: Getting more than one result from solve
Greetings Sirs,
I have recently aquired Maple for some mathematics, and being a new user, I basically google for everything at the moment.
While it has gone well so far, I seem to have hit a bump that I cannot figure out.
I have a function: f(x)=3.2+0.4sin(1.25x), 0<x<5
Trying to find the places where "f(x)=3.5" would normally be done with the equation "3.5=3.2+0.4sin(1.25x)", and when I solve for the equation in Maple I get a solution too.
Problem is though, I know there is supposed to be multiple solutions. Having used wolframalpha, and being capable of seeing the plot in Maple, I know there is two points within the period "x=0..5" that is the solution.
But when I try to solve the equation, I get only one solution per solve, and the second solve doesn't make much sense for me. These are what I use:
As you can see, in the first solve the entire function is being taking into consideration, yet I only get one solution... In the second solve I have tried specifying a period, but I still only get one solution.
Basically any help here is appreciated, because from what I understand, having read google, the solve command or fsolve command is supposed to give multiple results if they are there.
With appreciation,
Ciesi
(Edit: Image size changed)
