Question: How to build your own random variable?
Here's a problem that's been bothering me for a long time:
The Statistics[Distribution] help page describes the way to construct one's own Random Variable (RV).
All the examples construct a distribution foo := Distribution(...) next used to define the RV X by typing
X := RandomVariable(foo)
On the other way, constructing a RV Y from predefined Maple's distributions writes
Y := RandomVariable(bar(sequence of parameters))
The "user defined RV feature" (MyRV := RandomVariable(foo)) seems to be restricted to distributions where all the parameters are numerically instanciated, contrary to "Maple's defined distributions" where these parameters can be kept formal).
So my question: Is it possible to define your own Distribution (module foo) in such a way that the definition of the RV X writes
X := RandomVariable(foo(sequence of parameters))
The attached file contains an example for the Levy distribution (the second part is just a workaround where a substitution is used to balance my inability to define a RV the way above)
with(Statistics):
A particular Levy distribution
Levy Distribution  Levy(m=0, s=1)
m : location parameter
s := dispersion parameter
m := 0:
s := 1:
pdf := unapply(piecewise(x<0, 0, sqrt(s/2/Pi)*exp(-s/2/(x-m))/(x-m)^(3/2)), x);
cdf := unapply(erfc(sqrt(s/2/(x-m))), x);
samplingMethod := proc(N)
                     m +~ s /~ ( Quantile~(Normal(0, 1), Sample(Uniform(1/2, 1), N)) )^~2
                  end proc;
proc (x) options operator, arrow; piecewise(x < 0, 0, (1/2)*2^(1/2)*exp(-(1/2)/x)/(Pi^(1/2)*x^(3/2))) end proc
proc (x) options operator, arrow; erfc((1/2)*2^(1/2)*(1/x)^(1/2)) end proc
proc (N) `~`[:-`+`](m, ` $`, `~`[:-`/`](s, ` $`, `~`[:-`^`](`~`[Statistics:-Quantile](Normal(0, 1), Statistics:-Sample(Uniform(1/2, 1), N)), ` $`, 2))) end proc
Levy := Distribution(
                      PDF=(x->pdf(x)),
                      CDF= (x->cdf(x)),
                      RandomSample = (N->samplingMethod(N))
_m4561537536
X := RandomVariable(Levy):
PDF(X, x);
Sample(X, 5);
piecewise(x < 0, 0, (1/2)*sqrt(2)*exp(-1/(2*x))/(sqrt(Pi)*x^(3/2)))
Vector[row]([.569870365734461, .357020836498979, 39.1445163385190, .340597592385078, 1.23209867072410])
How should I define a formal Levy distribution in such a way that, as for any predefined RV in Maple,
a particular instance is defined by  X := RandomVariable(Levy(M, S))
where M and S are numerical values?
m := 'm':
s := 's':
                  end proc;
proc (x) options operator, arrow; piecewise(x < 0, 0, (1/2)*2^(1/2)*(s/Pi)^(1/2)*exp(-(1/2)*s/(x-m))/(x-m)^(3/2)) end proc
proc (x) options operator, arrow; erfc((1/2)*2^(1/2)*(s/(x-m))^(1/2)) end proc
                      PDF=(x->pdf(x)),
                      CDF= (x->cdf(x)),
PDF(X, x);
print();
# here is an inelegant workaround
ms := {m=0, s=1};
subs(ms, PDF(X, x));
piecewise(x < 0, 0, (1/2)*sqrt(2)*sqrt(s/Pi)*exp(-(1/2)*s/(x-m))/(x-m)^(3/2))
ms := {m = 0, s = 1}
piecewise(x < 0, 0, (1/2)*2^(1/2)*(1/Pi)^(1/2)*exp(-(1/2)/x)/x^(3/2))
u := Sample(X, 2);
# The substitution doesn't work
subs(ms, u);
u := Vector[row](2, {(1) = m+HFloat(1.7545213270590625)*s, (2) = m+HFloat(0.332342758403606)*s})
Vector[row]([m+1.75452132705906*s, m+.332342758403606*s])
# just a copy-paste of lprint(u): the substitution does work
lprint(u);
subs(ms, Vector[row](2, {1 = m+HFloat(2.49542958430755446)*s, 2 = m+HFloat(4.80772083491271562)*s}, datatype = anything, storage = rectangular, order = Fortran_order, shape = []))
Vector[row](2, {1 = m+HFloat(.529024707466874800)*s, 2 = m+HFloat(1.50334452451578438)*s}, datatype = anything, storage = rectangular, order = Fortran_order, shape = [])
Vector[row]([2.49542958430755, 4.80772083491272])
Download My-own-random-variable.mw
