've written in Maple to set up and solve the differential equation for a simple harmonic oscillator and plot the solution. To incorporate the Hamiltonian into my worksheet, I needed to define the kinetic energy and potential energy of the system, and then combine them to express the total Hamiltonian. After that, I can calculate and plot the kinetic, potential, and total energies over time. Then I plotted the kinetic energy, potential energy, and total energy over time
Hamiltonian Energy
In a linear simple harmonic oscillator (SHO), the Hamiltonian energy represents the total energy of the system, which is a combination of its kinetic and potential energy.
1. |
Position and Momentum:
Let be the displacement of the oscillator from its equilibrium position.
Let be the momentum of the oscillator.
2. |
Hamiltonian ( ):
For a linear SHO, it is given by:
Kinetic energy depends on the mass of the object and its velocity. In physics, it's expressed as:
where:
is the mass of the oscillator,
*of*momentum, p = mv, be*can*energy*kinetic*re*the-as*expressed; T = p^2/(2*m)](/ViewTemp.ashx?f=4065368_1729814832/f1e5f6b89abfb1ec755bbab43b66819f.gif)
This equation shows that kinetic energy increases with the square of the momentum.
4. |
Potential Energy ( )
Potential energy in a simple harmonic oscillator arises from the restoring force of the spring. The potential energy is given by:
is the spring constant, and
is the displacement from the equilibrium position.
This means that the further the mass is displaced from equilibrium, the greater the potential energy stored in the system.
(1) |
(2) |
(3) |
![plot_1 := subs(A = 1, sol); plotsresult := plot([rhs(plot_1)], t = 0 .. 2, legend = ["0.1cos(10 t)"], color = [red])](/ViewTemp.ashx?f=4065368_1729814832/26b5f696fdd18e8a60b9dfa9836ecc88.gif)
![directionfield := DEplot([diff(x(t), t) = v(t), diff(v(t), t) = -omega^2*x(t)], [x(t), v(t)], t = 0 .. 10, x = -2 .. 2, v = -10 .. 10, arrows = medium, title = "Direction Field for Simple Harmonic Oscillator", axes = boxed)](/ViewTemp.ashx?f=4065368_1729814832/38fb5870864b463f706ef9e2c3117fc2.gif)
(4) |
(5) |
![phase_plot := plot([[eval(x1, t = tval), eval(v1, t = tval), tval = 0 .. 10], [eval(x2, t = tval), eval(v2, t = tval), tval = 0 .. 10], [eval(x3, t = tval), eval(v3, t = tval), tval = 0 .. 10], [eval(x4, t = tval), eval(v4, t = tval), tval = 0 .. 10]], style = line, title = "Phase Portrait for Simple Harmonic Oscillator", labels = ["x (Displacement)", "v (Velocity)"], color = ["red", "blue", "green", "orange"], legend = ["A=1, v0=0", "A=0.5, v0=0", "A=-1, v0=0", "A=0.7, v0=0.5"], axes = boxed)](/ViewTemp.ashx?f=4065368_1729814832/ed81a5b0a069bccc4b530113d9d85ace.gif)
(6) |
![energy_plot := plot([eval(T), eval(V), eval(H)], t = 0 .. 2, color = [red, blue, green], legend = ["Kinetic Energy", "Potential Energy", "Total Energy"], title = "Energy Exchange in Simple Harmonic Oscillator", labels = ["Time (s)", "Energy (Joules)"])](/ViewTemp.ashx?f=4065368_1729814832/2a0e32ee6266d35d46bf67f0c8f0f183.gif)
Download Hamiltonian_Energy.mw
Now, in the second worksheet, I tried to create a procedure to calculate the Hamiltonian Energy for a general example. I have set delta = 0
: This removes the damping effect, leaving only the spring constant k
and mass m
as factors. Now the equation represents a pure simple harmonic oscillator:
The Hamiltonian (total energy) should be conserved, meaning it will remain constant over time without damping. The plot of H(t)
should show a straight line, indicating that the kinetic and potential energy sum does not change. But as you can see the energy increases over time. I can not figured out where is my mistake in this code
Any guidance or examples of implementation would be greatly appreciated!
Thank you!
Download Hamiltoninan_procedure_.mw
