Question: weakness in odetest?
I have more examples like this. Sometimes odetest give false negative result. dsolve solution is actually correct, but odetest does not return all zeros as result of its checking.
Example 1
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, 16:4 hours Pacific Time.`
SupportTools:-Version();
ode:=x^2*diff(y(x),x)+sin(2*y(x)) = 1;
IC:=y(infinity)=11*Pi/4;
maple_sol:=dsolve([ode,IC]);
odetest(maple_sol,[ode,IC])
x^2*(diff(y(x), x))+sin(2*y(x)) = 1
y(infinity) = (11/4)*Pi
y(x) = -arctan((x+2)/(x-2))+3*Pi
[0, undefined]
#but the IC above should not be undefined. This belows shows it is correct.
limit(maple_sol,x=infinity);
limit(y(x), x = infinity) = (11/4)*Pi
#which is what the IC is.
Download odetest_problem_oct_8_2025.mw
Would you agree that odetest in the above should have returned [0,0] instead? Should this result be considered a bug?
Example 2
More examples where odetest gives false negative. The solution by dsolve is correct but odetest says IC is off but it is not.
ode:=x^2*diff(y(x),x)+cos(2*y(x))=1;
IC:=y(infinity)=10/3*Pi;
x^2*(diff(y(x), x))+cos(2*y(x)) = 1
y(infinity) = (10/3)*Pi
y(x) = (7/2)*Pi-arctan((1/3)*(3^(1/2)*x+6)/x)
odetest(sol,[ode,IC]);
[0, -(1/6)*Pi]
limit(sol,x=infinity);
limit(y(x), x = infinity) = (10/3)*Pi
Download odetest_problem_oct_11_2025.mw
Example 3
ode:=x^2*diff(y(x),x)*cos(y(x))+1=0;
IC:=y(infinity)=16/3*Pi;
x^2*(diff(y(x), x))*cos(y(x))+1 = 0
y(infinity) = (16/3)*Pi
y(x) = arcsin((1/2)*(3^(1/2)*x-2)/x)+5*Pi
[0, (1/3)*Pi]
limit(y(x), x = infinity) = (16/3)*Pi
Download odetest_problem_oct_11_2025_V2.mw
Example 4
ode:=diff(y(x),x)*sin(x)-y(x)*cos(x)=-sin(x)^2/x^2;
IC:=y(infinity)=0;
(diff(y(x), x))*sin(x)-y(x)*cos(x) = -sin(x)^2/x^2
y(infinity) = 0
y(x) = sin(x)/x
[0, undefined]
limit(y(x), x = infinity) = 0
Download odetest_problem_oct_11_2025_V3.mw
Example 5
ode:=x*y(x)^2+exp(x)*diff(y(x),x)=0;
IC:=y(infinity)=1/2;
x*y(x)^2+exp(x)*(diff(y(x), x)) = 0
y(infinity) = 1/2
y(x) = -1/(x*exp(-x)+exp(-x)-2)
[0, undefined]
limit(y(x), x = infinity) = 1/2
Download odetest_problem_oct_11_2025_V4.mw
Will add more examples as I find them....
