Question: How to make solve() not be affected by earlier calls to solve? Error, (in is/duplicates:-Normal) too many levels of recursion
Just found strange bug in Maple.
If I do solve(eq1...) then solve(eq2,...) then the second solve now gives internal error.
But If I do (from clean start)  just solve(eq2,...) then it times out ok, No internal error. So clearly the first call to solve changed something in internal memory/cache to do this.
Is there a way to correctly "clear" solve cache or its memory tables after each call, so that earlier calls to solve do not affect future calls behavior? Was going to add this to my collection of maple bugs post, but thought a new question will be better to make it easier to reply.
The problem is that these internal Maple errors can not be cought by try/catch. Which means the whole program crashes and there is no way to continue automatically.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, 16:4 hours Pacific Time.`
SupportTools:-Version();
solve timesout OK if no call made before it
kernelopts('assertlevel'=2):
eq_2:=1 = -X*((1/2/(2*X*Y*a+2*X*a*y0+2*Y*a*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*Y*(2*Y
*a+2*a*y0)+1/2/(2*X*Y*a+2*X*a*y0+2*Y*a*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*y0*(
2*Y*a+2*a*y0))/(-2*X*Y*a-2*X*a*y0-2*Y*a*x0-2*a*x0*y0+Y^2+2*Y*y0+a^2+y0^2)-(-a*Y
-a*y0+(2*X*Y*a+2*X*a*y0+2*Y*a*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*Y+(2*X*Y*a+2*
X*a*y0+2*Y*a*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*y0)/(-2*X*Y*a-2*X*a*y0-2*Y*a*
x0-2*a*x0*y0+Y^2+2*Y*y0+a^2+y0^2)^2*(-2*Y*a-2*a*y0))/Y/((-a+1/2/(2*X*Y*a+2*X*a*
y0+2*Y*a*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*Y*(2*X*a+2*a*x0-2*Y-2*y0)+(2*X*Y*a
+2*X*a*y0+2*Y*a*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)+1/2/(2*X*Y*a+2*X*a*y0+2*Y*a
*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*y0*(2*X*a+2*a*x0-2*Y-2*y0))/(-2*X*Y*a-2*X*
a*y0-2*Y*a*x0-2*a*x0*y0+Y^2+2*Y*y0+a^2+y0^2)-(-a*Y-a*y0+(2*X*Y*a+2*X*a*y0+2*Y*a
*x0+2*a*x0*y0-Y^2-2*Y*y0-y0^2)^(1/2)*Y+(2*X*Y*a+2*X*a*y0+2*Y*a*x0+2*a*x0*y0-Y^2
-2*Y*y0-y0^2)^(1/2)*y0)/(-2*X*Y*a-2*X*a*y0-2*Y*a*x0-2*a*x0*y0+Y^2+2*Y*y0+a^2+y0
^2)^2*(-2*X*a-2*a*x0+2*Y+2*y0)):
try
    timelimit(30,solve(identity(eq_2,X),[x0,y0]));
catch:
    print("good. No crash");
end try;
"good. No crash"
Same solve gives internal error when calling another solve before it
eq_1:=1 = -X*(1/2*(2*X*Y^3-4*X*Y^2*a+6*X*Y^2*y0-8*X*Y*a*y0+6*X*Y*y0^2-4*X*a*y0^2+2*X*
y0^3+2*Y^3*x0-4*Y^2*a*x0+6*Y^2*x0*y0-8*Y*a*x0*y0+6*Y*x0*y0^2-4*a*x0*y0^2+2*x0*
y0^3+2*X*Y+2*X*y0+2*Y*x0+2*x0*y0)/(X^2*Y*a+X^2*a*y0+2*X*Y*a*x0+2*X*a*x0*y0+Y*a*
x0^2+a*x0^2*y0+X^3+3*X^2*x0+3*X*x0^2+x0^3)-1/2*(X^2*Y^3-2*X^2*Y^2*a+3*X^2*Y^2*
y0-4*X^2*Y*a*y0+3*X^2*Y*y0^2-2*X^2*a*y0^2+X^2*y0^3+2*X*Y^3*x0-4*X*Y^2*a*x0+6*X*
Y^2*x0*y0-8*X*Y*a*x0*y0+6*X*Y*x0*y0^2-4*X*a*x0*y0^2+2*X*x0*y0^3-Y^3*a^2+Y^3*x0^
2-3*Y^2*a^2*y0-2*Y^2*a*x0^2+3*Y^2*x0^2*y0-3*Y*a^2*y0^2-4*Y*a*x0^2*y0+3*Y*x0^2*
y0^2-a^2*y0^3-2*a*x0^2*y0^2+x0^2*y0^3+X^2*Y+X^2*y0+2*X*Y*x0+2*X*x0*y0+Y*x0^2+x0
^2*y0)/(X^2*Y*a+X^2*a*y0+2*X*Y*a*x0+2*X*a*x0*y0+Y*a*x0^2+a*x0^2*y0+X^3+3*X^2*x0
+3*X*x0^2+x0^3)^2*(2*X*Y*a+2*X*a*y0+2*Y*a*x0+2*a*x0*y0+3*X^2+6*X*x0+3*x0^2))/Y/
(1/2*(3*X^2*Y^2-4*X^2*Y*a+6*X^2*Y*y0-4*X^2*a*y0+3*X^2*y0^2+6*X*Y^2*x0-8*X*Y*a*
x0+12*X*Y*x0*y0-8*X*a*x0*y0+6*X*x0*y0^2-3*Y^2*a^2+3*Y^2*x0^2-6*Y*a^2*y0-4*Y*a*
x0^2+6*Y*x0^2*y0-3*a^2*y0^2-4*a*x0^2*y0+3*x0^2*y0^2+X^2+2*X*x0+x0^2)/(X^2*Y*a+X
^2*a*y0+2*X*Y*a*x0+2*X*a*x0*y0+Y*a*x0^2+a*x0^2*y0+X^3+3*X^2*x0+3*X*x0^2+x0^3)-1
/2*(X^2*Y^3-2*X^2*Y^2*a+3*X^2*Y^2*y0-4*X^2*Y*a*y0+3*X^2*Y*y0^2-2*X^2*a*y0^2+X^2
*y0^3+2*X*Y^3*x0-4*X*Y^2*a*x0+6*X*Y^2*x0*y0-8*X*Y*a*x0*y0+6*X*Y*x0*y0^2-4*X*a*
x0*y0^2+2*X*x0*y0^3-Y^3*a^2+Y^3*x0^2-3*Y^2*a^2*y0-2*Y^2*a*x0^2+3*Y^2*x0^2*y0-3*
Y*a^2*y0^2-4*Y*a*x0^2*y0+3*Y*x0^2*y0^2-a^2*y0^3-2*a*x0^2*y0^2+x0^2*y0^3+X^2*Y+X
^2*y0+2*X*Y*x0+2*X*x0*y0+Y*x0^2+x0^2*y0)/(X^2*Y*a+X^2*a*y0+2*X*Y*a*x0+2*X*a*x0*
y0+Y*a*x0^2+a*x0^2*y0+X^3+3*X^2*x0+3*X*x0^2+x0^3)^2*(X^2*a+2*X*a*x0+a*x0^2)):
timelimit(30,solve(identity(eq_1,X),[x0,y0]));
#now try same solve as in first example
try
catch:
end try;
Download second_sovle_fail_maple_2025_1_oct_21_2025.mw
