clear variable from MEMORY
March 17 2010 by ndattani 549
false
Maple
I found this on a website:
To clear all variables in Maple and restart without having to reload the application, enter:
This will clear all values, unload all packages, and reinitialize Maple. However, this command will not free up memory previously allocated to Maple; consequently, when doing large jobs, the only way to improve speed is to exit and restart Maple.
Does this mean I can't clear any variables from memory at all without closing maple ??
In matlab all you have to do is:
clear('x')
and that will clear the variable x from memory (you can see that the amount of memory allocated to matlab goes down if you look at the windows task manager)
In maple when I clear the variable x by applying the command:
x:='x'
the amount of memory allocated to maple remains the same.
I'm hoping that that website was wrong and there is a way around this because being able to clear a huge variable that's only needed for the initial stages of a long computation is extremely important - any software should be able to do this.
Loading Comments & Answers
