sequences with units
January 11 2007 by dgiznya 100
false
Maple
Is it possible to define sequences or lists etc with units?? t:= (seq(100[s]..2000[s],100[s])); and t:=seq(100[s],200[s],300[s]); flag an error. if not is it possible to define the sequence, how can you append the units after a calculation. I want to perform the same calculation using units w/ one of the parameters varying to produces a list of calculated outputs all w/ units. Possible? Easy? e.g. v=d/t simple enough. well how can I generate a series of outputs from the above time sequences at a fixed distance d that spits out the velocities with units of m/s? Thanks, DG
Loading Comments & Answers
