Constraints using NLPSolve
July 27 2010 by petrivka 45
false
Maple 12
Hello all,
I'm working through an optimization problem, and I'm running into a problem adding constraints on the variables I am trying to optimize. I'll attempt to ask the question in a general sense, but if it's not clear, I'll be more specific.
I have a procedure called EIG that calculates the sum of the squared residuals of a model compared to experimental data by inputting 6 variables. I'm trying to minimize this function by using the Optimization function in Maple 12. What follows is the command I'm executing:
Optimization:-NLPSOLVE(EIG,method=nonlinearsimplex,initialpoint=[10,175,0.58,0.006,0.011,0.0001],evaluationlimit=100)
Generally, this works fairly well (and takes a few hours to compute). However, now I'd like to add a constraint to the final variable, but I know that the nonlinearsimplex method does not allow me to constrain the problem in any way. I tried switching to the sqp method, but I seem to get all kinds of errors when I try to constrain any of the variables. How would I correctly add a constraint (say, for the final variable to be less than 0.006)?
I'm sorry if this seems simple, but I'm currently stuck on this issue, and any help would be appreciated!
Loading Comments & Answers
