How to simplify equations under a certain condition?
October 04 2010 by Wang Gaoteng 148
false
example.3.mwsometimes, the system differential equations contain many parameters, such as K[t],K[a],L[a],R[a],etc.
Now, we input these differential equations to maple,namely,deq:=[...,...,...,...], of course, this input procedure consume much time.
Using sys:=DiffEquation(deq,[inputvariables],[outputvariables]) and tf:=TransferFunction(sys) yield the system transfer function.
Come under analysis, I find that a parameter, L[a], which cases the relative effect on the system can be neglected, so, I can set L[a]=0 in the differential equations.But as you know, the number of equations are a lot,and it is not easy to select L[a] in these equations.
Is there any way to substitute L[a]=0 into the former equations automatically, for example, let L[a]=0 in the former equations deq:=[...,...,...,...], and yield equations which won't contain the L[a] terms again?
Thank you very much!
Best Regards!
Loading Comments & Answers
