Question: pdsolve produces faulty result on heat equation with..
can someone give help or a hint on how to overcome the faulty result in the pdsolve problem with radiation bc described in the following worksheet? I tried also with different method, but no success. the result from pdsolve makes physical no sense, because under pure radiation bc (h=0) the body should cool down and not heat up!
maple_heat_rad_pdsol.mw
btw, the problem was reported befor, see:
http://www.mapleprimes.com/questions/97391-Whats-Wrong-With-Maple-Solution
