Question: filling an array procedure
Hello, I've got a simple question in Maple7. I tried to fill the array "intXdA()" in the for-loop but I failed. How I have to declare it after "global" in the beginning? Is it possible to declare it after "n" is determined - so that it has n elements?
with(plots):
> flsp:= proc(f,ug,og) global i,n,intXdA()
   y:=unapply(f,x):
   if  ug<0 and og=0 then n:=1 end if:
   if ug<0 and og>0 then n:=2 end if:
   for i from 1 by 1 to n do intXdA(i):=evalf(int(x*y(x),x=ug..og)): end do;
   end:
> flsp(x,-4,0);
For any tip I will be very grateful.
Thanks for your help!
