Question: [Maple 15][Linux 64Bit] Bug in integration over a domain on Linux amd64
Hi! I'm running Maple 15.01 64Bit on my Xubuntu 12.04.
I also got Maple 15 installed on my Windows7 64Bit computer to verify the results.
So let's see what is going wrong:
What does work?
int(x^n, x);
Gives me on both machines the correct result:
int( x^n, x)
int(x^n, x=1..1);
Gives me on both machines the correct result as well: 0
What does not work?
Integration over a domain with a (negative) exponent in the function:
int(x^n, x=2..3)  // in this example n is undefined
Expected result and actual result on Win7:
int( x^n, x=2..3)
Result on Linux:
int( x^n, x=2..3)
i.e. Maple doesn't evaluate the integral but indeed simplifies it:
int((x-2*x)^n, x=2..3^3);
results in
int((-x)^n, x=2..9)
on Linux.
Further I tried to alter the exponent n:
Same incorrect result for all n < 0! But works for n >= 0!
What did I try to solve the problem so far?
1.) Put an an evalf() around the integral: Didn't change anything
2.) Reinstalled Maple on Linux: No improvements.
Can anyone of you reproduce the bug? Any suggestions or ideas what is going wrong?
Best Greetings,
Marc
