Question: How to apply the D operator to an indefinite sum?
I have an indefinite sum, for instance:
> E := Sum(f@g@@k, k=0..n);
If I use D(E), I just get: D(Sum(f@g@@k),k = 0 .. n)
> D(f@g@@k) gives the expected result: D(f)@g@@k * D(g@@k)
Doing this works:
> F := Sum(D(op(E)[1]), op(E)[2]);
   F := Sum(D(f)@g@@k * D(g@@k), k=0..n)
However I want to apply it to complex expressions containing Sums and Products. And I can't check if E is of type indefinite sum. The hasfun(E, Sum) searches recursively, it doesn't tell if the top level function is Sum.
Is there any way around this?
*Edit: maybe my question isn't clear enough. I want a way to transform
> E:=Sum(function, k=0..n);
into:
> E:=Sum(D(function), k=0..n);
But only when E is of type indefinite sum.
