Question: Assign a range to a fitting variable
Hello everyone
I'm trying to do a fit for some points using a model function. However, I don't want to use the full range of the independent variable in the model function because I know there will be no fit then. How to assign a range for the fitting variable?
In the case my writing is not clear, here is what I mean:
xdata:=points
ydata:=points
modelfunction:=f(x,parameters)
Fit(f(x,parameters),xdata,ydata,x,rangeofx=r);
I can't do that, only thing I can do is specify the range of the parameters.
Thanks for your help
