Question: why has the plot command deteriorated
A plot command with the only argument of
sqrt(75-3*x^2)
used to work (up through version 15).  With 16.02 Maple produces nothing but axes.  It is still smart enough to use its default range for the x-axix and to figure out an appropriate range for the y-axis, but it cannot (will not) draw the curve.
If I were a student wanting to answer a prof's question about that curve, I should not need to do any analysis to get a rough picture of what I'm dealing with.  If I was a student, then if I was careful enough to figure out to ask for a range of x=-5..5 or shorter, then I probably do not need Maple to draw it for me in the first place.
Related issue:  if I ask for a plot with x=-8..8 and y=-10..10 then that is what I should get in the way of axes.  Now frequently one must wait for a plot to be drawn, then right click on it and use the context menus to again specify those axis ranges.
