Question: Float problem for Integral expression
Dear Experts,
I am novice to Maple 14, to do some numerical work I am using its 2D math input. I am having problem while using an itegral equation with a limit from 0 to infinity, when I use this limit; in answer I got un-solved equatoin instead a numerical value and this un-solved equation have FLOAT value, when I tried with some other input that time maple give answer again FLOAT(infinity) error
The equations which I tried are published in some research papers and they got some numeriacal values but maple did't give me the numeric answer for same inputs & procedure
When I change limit lets say 0.1 to 1000, it gives me answer but this answer is not much accurate (difference is ~9%). Even problem in other possible cases, like for  0 ... 1000 and 0.1 .... infinity
Here I am attaching both maple files, in one limit = 0 ... infinity -> Eq-0-inf.mw
                                                      in second limit = 0.1 ... 1000 -> Eq-0.1-1000.mw
Can any one tell me how get rid of......
