Question: Abstract multi variable expression
Hello everybody,
I'm completely new to Maple (installed it today) and have a question about the use of multi variabele expressions. I wanted to use a function B depending from the variables a, b, c and d without describing the expression explicit.
For example: B:= (a, b, c, d);            [without the -> a....]
Then I wanted to take the taylor expansion of the first order for [a=e, b=f, c=g, d=h] (see next line) but it didn't work.
For example: mtaylor(B, [a=e, b=f, c=g, d=h], 1);
Gives: Error, (in mtaylor) 3rd argument (the order) must be a non-negative integer
What am I doing wrong? I do want to work with a abstract expression as above.
Kind regards,
S.
