Question: Using modelica standard lookup tables in maplesim
I'm importing some other modelica models from other softwares (like open-modelica and dymola) inside maplesim. I can work in a full compatible code, except for the lookup table. Some of the models I'm importing as a library uses the standard lookup tables (not the ones given by maplesim) - I tried to run those standard lookup tables (from the modelica library) in maplesim, but it does not work.
Is there a way to solve this problem? In summary, to run lookup tables from the Modelica Library in Maplesim?
Thank you for the support
