Question: Maple 17 causes SC/32A fatal errors and prompts to reinstall DOS/32 for local admin command window
This is a very strange and specific issue I am having with any Windows x86 vm after having installed Maple 17.
Before installing Maple 17 (and also AFTER installing it, before the reboot), I can open a command window while logged in as the local administrator and successfully issue a command like:
sc config BDESVC start= disabled
After installing AND REBOOTING for Maple 17, if I log in as the local administrator, open a command window, and issue the same command, I get this error:
c:\users\Administrator>sc config BDESVC start= disabled
DOS/32A -- Protected Mode Run-time Version 7.2
Copyright (C) Supernar Systems, Ltd. 1996-2002
SC/32A fatal: DOS/32A environment variable is not set up properly
You need to reinstall DOS/32 Advanced DOS Extender on this computer
C:\Users\ADMINI~1>
...you'll notice after the failure, the path in the prompt goes to a 8.3 naming convention ("C:\Users\ADMINI~1").
In this situation, if I right-click on cmd.exe and specifically choose to "run as administrator", I can issue the sc command with no problem.  But for some reason I don't fully understand, after installing Maple 17, I have lost the ability to run any SC commands (not just BDESVC, but any such command) without specifically elevating, even though I am logged in as "Administrator" (the local administrator), and I could do it before without any issues.
SO....what on earth has Maple 17 changed, and how can I set it back?
