Question: How can i display numerical data?
Hi, I need some help with my code. I got the code that you can see below:
> with(DEtools);
> with(plots);
> cc := Array(["Blue", "Red", "DarkGoldenrod", "Black", "LimeGreen", "DarkMagenta", "Indigo"]);
> ll := Array(["dash", "longdash", "spacedash", "solid", "spacedot", "dot", "dashdot"]);
> L := 10;
> N := 1;
> eq1 := (diff(g(t), t))/t = -(1/2)*f(t)^2*(1-f(t)^2);
> eq2 := diff(f(t), t) = f(t)*g(t)/t;
> sys_ode_LIV := eq1, eq2;
>bcs_LIV := g(0) = N, f(L) = 1
> sys1a := {bcs_LIV, sys_ode_LIV}
>sysx := eval(sys1a):
dsnx := dsolve(sysx, numeric, method = bvp[midrich], continuation = lambda, maxmesh = 20000, initmesh = 20000, abserr = 10^(-2), output = listprocedure):
print(plots:-odeplot(dsnx, [[t, f(t)], [t, g(t)]], t = 0 .. 10));
How can i display numerical data instead of plots? This code just give me curves, but I need the values that Maple use to make the plot, how I do that?
thank you so much for your time and attention.
best regards...
