Question: how to do a point plot if there is a range in value and in different colour
Hi there..
I have a question on how to do a pointplot.
before plotting, I need to know the value of lambda[j] and  all the values of lambda already have.
so now I need to plot a graph with the values of lambda with different range and different colour,
Let say I have
> for j from 17 to 32 do k[j] := j+1;
x[j] := add(P[j, 1], j = j-1 .. j+2);
X[j] := add(P[j, 1]^2, j = j-1 .. j+2);
y[j] := add(P[j, 2], j = j-1 .. j+2);
Y[j] := add(P[j, 2]^2, j = j-1 .. j+2);
xy[j] := add(P[j, 1]*P[j, 2], j = j-1 .. j+2);
cx[j] := evalf(x[j]/k[j]);
cy[j] := evalf(y[j]/k[j]);
c11[j] := evalf(X[j]/k[j]-cx[j]^2);
c22[j] := evalf(Y[j]/k[j]-cy[j]^2);
c12[j] := evalf(xy[j]/k[j]-cx[j]*cy[j]);
C[j] := evalf(Matrix(2, 2, [[c11[j], c12[j]], [c12[j], c22[j]]]));
E[j] := simplify(fnormal(LinearAlgebra[Eigenvalues](C[j])));
if E[j][1] > E[j][2] then lambda[j] := E[j][2]/(E[j][1]+E[j][2]) else lambda[j] := E[j][1]/(E[j][1]+E[j][2])  end if;
lambda[j];
 end do;
the range of lambda [j] are as follows:
 0.02< lambda [j]<0.06
 0.06< lambda [j]<0.12
 0.12< lambda [j]<0.18
for i from 17 to 32, do if   0.02< lambda [j]<0.06 then green[i]:=P[i,j]; j:=i+1 elif
 0.06< lambda [j]<0.12 then red[i]:=P[i,j];j:=i+1 ; elif 0.12< lambda [j]<0.18 then blue[i]:=P[i,j];j:=i+1 end if;end do
how to do a point plot with the above situation so that in my plotting all the information are on the same graph.
All help is greatly appreciated.
