Question: Change Plotting order
Is it possible to change the order of which polygons are plot? I searched a lot on the internet but I don't find a useful answer. It seems to be logical that they are plot in the order they are given to the command "display", but it don't seem to work.
I try to plot different polygons, like you can see in the images below:
The red planes should form a pyramid but the black ground plane is front of it, so it should be plotted before the four red planed (polygons) are plotted.
In the code, the black plane (pp6) comes before the red planes (pp7->pp10) as input of the display command. If I change the order, nothing changes in the plot.
Is it possible to tell Maple that some polygons should be on the foreground and some on the background?
 Here is a link to the file if necessary: translatie_stn.mw
Thanks in advance!
