Question: generate 3d cube from polygon surface
Is there an easy way, where I can generate a 3d cube when I have already defined a 3d polygon surface?
I would like to sweep my surface 20 cm in the z-axis, preferably without having to define the cube from it's 8 corners.
Is there a command I can use for this purpose?
